Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water leaking from whirlpool washer
Problem seems to becoming from behind the metal backing of the machine but leaks toward the front. how d o we take the backing off?
    President:
  • 1,314 Answers
Facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down.
Posted on Jan 12, 2008
This is an Estate Whirlpool washer. It is leaking water from underneath? Check all hoses on back and they are dry(not leaking). Any suggestions?
could be 2 thigs the outer platic tub is broken or transmission or transmission seals are gone, go on line and see how to fix is very easy work on these machines.
Dec 27, 2015 | Estate Washing Machines
My whirlpool duet front load has been leaking. It leaks only when doing a load of laundry. Leak is coming out the back and on the right side. Took the front bottom off to see if I can see anything and...
First, make sure that the washing machine is not too close to the wall behind it. This could crimp the drain hose & force water out at the connection behind the machine. This could also crack/split the washer machine's port (to which the drain hose attaches). Second, check the hose clamp for a secure hold at the washer machine's port, & check the drain hose for leaks & for insertion in the drain tube at the wall.
Feb 22, 2015 | Whirlpool Washing Machines
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
My washer leaks water all the time
If it is leaking all the time while running it could be the drain pump. A coin had made its way into mine and cracked the housing. Itis located towards the right rear of the machine on the bottom, while standing in front of the machine.
Mar 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Water Leak
While I do agree with eagle338 that water could be leaking from the fill hoses and the pump area, the rest of the instructions apply more for a top load Maytag washer, instead of the front load Whirlpool washer you reported.
Most likely you will have a hole in the front boot area (grey rubber seal around where the door seats). If you find such a leak, send me a note back and I'll write you up a how to to change it out.
The second most common source of leaks come from holes in the tub. This is the white outer part that holds most of the water in the machine. You will easily be able to see it when you remove the panel as listed above in the clarification instructions.
On rarer occasions, you can have something stuck in the fill tube that goes from the dispenser to the tub. Somehow small items become lodged in there. There will be a water inlet about the 10 o'clock position of your boot (grey rubber seal). Probe gently in there with your finger to see if a sock or similiar item got spun into this area.
Jul 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking Water
check your rubber bellow you might have had something go threw it.
Jun 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
