Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Interior Water dispenser not working
I have the Stainless Steel Trio which I purchased in 2/07. I love it!
The water dispenser which was not used often stopped working. I can hear it trying to dispense by the hum when I push the button. I just changed the filter hoping it would be that easy. No luck.
The ice maker is working fine.
    Scholar:
  • 27 Answers
Hi . Its good to know the Make and Model number of your refrigerators when you ask for a solution. Each manufactures have their own design flaws that create operating problems. IF YOUR WATER LINE TO YOUR WATER DRINK DISPENSER KEEPS FREEZING AND ADJUSTING THE REFRIGERATOR TEMPERATURE A LITTLE WARMER DOESN'T HELP, THEN YOUR DAMPER BETWEEN YOUR FREEZER AND REFRIGERATOR COMPARTMENT IS LEAKING AIR IN THE CLOSED POSITION. THIS IS COMMON FOR MAYTAG, WHIRLPOOL AND SOME KENMORE. THIS CONDITION NORMALLY REQUIRES THE REPLACEMENT OF THE DAMPER ASSEMBLY, BUT SOME ARE CAUSED BY AIR LEAKING AROUND THE ASSEMBLY AND CAN BE SEALED WITH A PLUMBERS PUTTY. DON'T CAULK IT. YOU WANT TO BE ABLE TO REMOVE THE DAMPER IF NECCESSARY. IF YOU HAVE AN LG REFRIGERATOR, YOUR DAMPER COULD BE THE PROBLEM OR YOUR FREEZER TEMPERATURE MAY BE RUNNING TOO COLD. THEY HAVE BEEN KNOWN TO RUN BELOW ZERO DEGREES INTO THE NEGATIVE TEMPERATURES. THIS CAUSES THE STORAGE BINS AND WATER LINE TO FREEZE. A COMMOM MANUFACTURES MISTAKE IS WHEN THEY BUILT THIS REFRIGERATOR, THEY FORGOT TO PULL THE COMPARTMENT TEMPERATURE SENSORS OUT FROM THE FOAM OF THE REFRIGERATOR CABINET. THIS MAKES YOUR REFRIGERATOR KEEP RUNNING. IF YOU TAKE THE LITTLE COVER OFF YOU WILL SEE IF THE END OF THE SENSOR IS INSIDE THE COVER HOUSING OR STILL UP IN THE FOAM. BE VERY CAREFULL REMOVING IT FROM THE FOAM BECAUSE THE WIRES ARE THIN AND SHORT. TRY TO PIVOT THE TIP OUT ONLY. YOU DON'T HAVE TO HAVE IT ALL THE WAY OUT AS LONG AS THE END IS NOW INSIDE THE SENSOR COVER. THESE COVERS ARE LOCATED INSIDE ON THE TOP AROUND THE MIDDLE AREA. CHECK ME OUT ON EBAY AS USERNAME themackshack. GOOD LUCK! MACK
Posted on Feb 03, 2008
Thanks!
The water line was frozen as I suspected. It runs very cold on the top area.
I didn't realize the water dispenser hose ran behind the left crisper drawer. Once the line was manipulated the blockage broke free.
Posted on Feb 02, 2008
I just had the same problem and symptoms. And it was reading your thread that put me on the right track. I put a thermometer inside and found that the temp was about 3 degrees colder than shown on the panel. I figured the line may be frozen in some area and turned the temp up 5 degrees. After about 10 hours I tried the dispenser and now am getting water out again. Maybe this will work for you - it was at least free!
Posted on Jan 25, 2008
6ya staff
SOURCE:
From the water filter, where does the water tubing connect to?
Some have a connection behind kickplate at bottom front.
Oct 08, 2017 | Whirlpool Refrigerators
Whirlpool refridgerator side by side is leaking water on the side. We do not know where it is leaking from
Often water leaks result in stains on the Stainless Steel, use DeBruce Polish for removal. Using DeBruce Polish on all your stainless steel will allow you to now perform JUST TOUCH UPS of finger printing and remove the need for "OILS" that manufacturers provide for cosmetic care of blending. Stainless IS A GREAT FINISH TO CARE FOR one just needs the right product. Once cleaned with DeBruce Polish there exists no oil or other "films" to BLEND. DeBruce Polish will now perform touch ups instantly. LOVE YOUR STAINLESS STEEL AGAIN! Get DeBruce Polish at debrucepolish.com NON-TOXIC AN ODORLESS ...PERFECT
Jan 06, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser not working on kenmore trio refrigerator
The tubing inside the door is most likely frozen. Mine did that a year ago. I had to remove gasket and loosen screws around edge and allow to defrost inside door. There was a lot of ice around dispenser and tubing.
Sep 16, 2012 | Kenmore TRIO® 77553 Stainless Steel Bottom...
White film on dishes and interior
White streaking is caused by too much rinse agent. (jet dry) Most all dishwashers now have adjustable rinse agent dispensers, so you can set them to a lower setting when you have soft water, and a higher setting if you have harder water. The adjustment is generally right where you add the jet dry. Other possiblilities would be a leaking jet dry cap, or a defective jet dry dispenser.
Apr 16, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Spots on freezer door
Use a product like lime-away may help. These water spots are caused from calcium buildup. Lime-away or similar product will dissolve the calcium. Then use the stainless cleaner on it.
May 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
if you have not yet used it you will need to bleed the air out of the tank in the refrigerator hold the button in for a few mins to flush this out
Jan 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
218 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
