Question about Billionton Bluetooth Class 1 Access Point + Broadband Router (100328000000) Wireless Adapter
Unable to log in to my Billion Router
Unable to log in to Billion Routre
0 characters
1 Points
Windows unable to find certificate to log on using netgear wna1100
Windows doesn't need a certificate to logon to the router.
It may need one to logon to a web page.
Check by accessing another web page.
Dec 02, 2013 | NetGear WNA1100 WirelessN 150 USB Adapter...
What website can I go to, to set up my own passwor...
You can set the wireless settings for your router by:
Open a web browser and enter and press Enter. When the login window appears, set the user name to admin and leave the password box empty. Click OK to continue.
If you are unable to log into the router using the default username you will need to reset the router back to factory settings by holding the reset button on the back for 10 seconds, then wait 30 seconds and try to log in using the default password.
May 20, 2010 | D-Link 802.11g Wireless Router WBR-1310...
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Wirless router not working
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem.
2. now connect the Ethernet cable to the modem & to the computer and see if that works.
else contact your isp.
for more help.
Sep 08, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I have a wireless network- 2 laptops plus 1 desktop usually connected wirelessly. Today, I hit the reset on my Tmobile Dlink router and I am unable to log on of my laptops back onto network. When I use...
try unplugging the router for about 5 minutes and then plugging it back in. I would also unplug the modem at the same time, then plugging the power back opn for the modem and then plugging the router back in too. should reset ur issues
Jul 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Adsl wireless n modem router
regard to G it can transfer signal up to 54mbps  and nano tech have even come to point now as its 130mbps more that ethernet cable but it depends on the factors such as heavy wall , and other interference such as sky , heavy speakers  microwave , bulgrar alarm so on with network booster like netgear it works 2 boost the wireless signal, regards 2 comparision 1 has advantage over the other
Oct 20, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Strange problem about WBR 1310
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then got to Startup click Disable All and then Apply and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Aug 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Unable to setup wireless network
I know exactly what has happened
u did not knew the password for router manager
u reset it
After reset router , it came back to its factory defaults, now the password will come back to its factory defaults ( if u still dont know the factory defaults password, check manual provided to u with this router )
After reseting , as router came back to factory defaults , it also changed the wireless encryption key or WPA password with which u were able to connect earlier to its factory defaults original key and due to that reason u are getting limited or no connectivity coz the WEP or WPA key has changed.
Solution: IF U know the original wireless key or WPA key try to reenter it and see whether it connects or not
if still does not work
Then connect ur PC or laptop with ethernet or LAN CABLE (CAT)
Your internet will start working with the cable
NOW u will be able to open the router manager page
Type the factory defaults password and log in
Then goto the wireless settings page and check what is the WEP key stored in ur router and also try to channels of the router and see wherher it increases the signal strength or not
Once you have got the key from the router manager page
Try to reenter it and then surely it will work.........
Best of luck
Feb 19, 2008 | Network & Wireless Adapters
Network & Wireless Adapters Logo
342 people viewed this question
Top Billionton Network & Wireless Adapters Experts
 C. Dante
C. Dante
Are you a Billionton Network and Wireless Adapter Expert? Answer questions, earn points and help others
