Question about HP Photosmart 335 GoGo InkJet Printer
Hp Photosmart 35 wont work just these numbers come up on screen
When I put in memory card, tried different ones, these numbers come up C0620004. I just got this machine for xmas and now it doesn't work could you please help me with this problem. thank you Debbie
  • 1 more comment
  • Anonymous Jan 16, 2008
    the numbers on mine are - 07A74DD6
  • justfavo Apr 05, 2008
    The same problem with photosmart335
  • HOt2tub May 25, 2008
    I have a photosmart 375 printer and this error code c0620004 comes up when I turn on the printer. Have tried nothing at this point except put in new ink cartridge and reboot.
    Thanks
I have same problem- I am receiving both codes... C0620004 and 07A74DD6.
Problem started out of the blue- was working wonderfully until now. No help from HP Tech support.
Posted on Sep 07, 2008
6ya staff
SOURCE:
PHOTOSMART 2575 DISPLAYS "MEMORY CARD
Insert a memory card (in my case a SD CARD) and SLOWLY extract card until error message clears and normal screen images appear.I had to do this several times but it worked for me but cannot guarantee it will for everybody.GOOD LUCK.
Jun 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart M425 card has wrong format press ok to format card unable to format
You could try formatting it in My Computer on PC by right clicking on its icon to bring down the option, then format again in the camera to ensure compatibility
Dec 15, 2010 | HP Photosmart M415 Digital Camera
I cannot Format the memory card on my camera,HP photosmart M627. Can you help?
Try to get hold of a usb card reader that support your memory card and format it on your pc, both the camera and the card reader is using the FAT 32 File System to format. The one i use is a Transcend RDP8 and can take five different cards
Dec 11, 2010 | HP PhotoSmart M627 Digital Camera
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
My hp photosmart r707 keeps saying the card is unreadable, buti just used it yesterday. i cant reset it either. it wont let me and the computer wont read it
Sounds like you're connecting things like your camera or your card in a card reader and just yanking them out of your computer without using the "safely remove hardware" icon at the bottom right of your computer screen.
Feb 06, 2010 | HP Photosmart R707 Digital Camera
I have a hp psc 2355 printer everytime i insert
I had the same problem with my HP L7590 All In One. After trying a number of things to reset nothing worked. Then I tried this just as a last resort and it worked.
Insert the/a memory card( it will tell you that you can only use one card at a time).
With the card still in turn off the printer using the power button.
Wait for 30 seconds then turn power on again.
The screen should say reading card. So wait for it to finish reading and all should be fixed.
If this does not work, try again using a different card.
good luck
Send me Kudos if it works.
Oct 25, 2009 | HP PSC 2410 All-In-One InkJet Printer
Wont accept xd picture card
Hi, tecnil
Device cannot detect files on the memory card.
Cause
The memory card might be missing or inserted incorrectly. Verify that the memory card is inserted correctly.
The files might not be in the correct format. To print from the device control panel, the files must be in the sRGB JPEG format. To print other formats, you must use a software program on your computer.
You might have inserted more than one memory card. Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
oke,
thx
cropp
Jan 08, 2008 | HP Photosmart 7450 InkJet Printer
Screen goes blank after memory card is in?
Are you putting it in the rightway round? Check the illustration under the cover or the manual. If you are contact HP tech help for the model of camera.
May 12, 2007 | HP Photosmart 620 Digital Camera
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
HP Camera won't turn on
I had the exact same problem. I turned on my HP Photosmart E317 camera and it would light up for one second and then just a blank screen. Here's the tech support site from HP. Try taking out your memory card and then turn it on. That worked for me. I just put the memory card back in and it works fine. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709691&lc=en&cc=de&dlc=de&product=445953&rule=2137&lang=de
Nov 16, 2006 | HP Photosmart 945 Digital Camera
HP Photosmart 335 GoGo InkJet Printer Logo
493 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
