Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
Getting to my radio's antenna plug
How do I pull my car radio out to install my sirrus antenna adapater
  • 102 Answers
Depends on the radio but with most models when you bought it new you would have gotten two flat strips pieces of metal which should be inserted left and right between the radio and the radio bay. They will push aside the spring locks and then you can gently pull it out.
Some info here and here and on google ofcourse :)
Posted on Jan 12, 2008
Repair radio antenna plug
Radio shach has a solderless antenna plug(but it is a generic type).You will probably have to get this plug and a GM adapter.(GM is the ONLY AUTO MANUFACTURER that doesn't use an antenna plug like the rest.
Dec 06, 2012 | 2006 Pontiac Sunfire
My antenna wire was cut at the antenna on my 1991 corvette. Is there an other plug in comewhere along the body
Hi this is Bishop.The easyest way is to find the spliced wire and tye a string to it TIGHT take the radio out and pull the antenna wire slowley untill the string comes.
Jul 06, 2012 | 1991 Chevrolet Corvette
2002 Chrysler Town & Country antenna installation
Did the antenna break off in the mount or did the mount break.If antenna broke off in mount I would try drilling and tapping it.If you need a whole mount.Remove plug from back of radio attach good mechanics wire to it undo outer mount when you pull the wire out of the car the mechanics wire will follow afer you get it out put the mechanics wire on the new one tape over the wire to make it a smooth transition and pull mechanics wire inside the vehicle to reroute the antenna wire back to the radio.Be carefull you shouldnt have to pull super hard
Jun 04, 2012 | 2002 Chrysler Town & Country
How do I connect Sirus XM for a 2006 escape using the audio cable? Does my radio have an input jack?
You will need to remove the radio and look at the rear for the input, if your radio doesnt have an input you can buy the kit to connect it to sirrus and instead of direct connect you can use a radio station to connect to sirrus,most newwer cars and trucks will come with an input but lower brand radios may not. the only way would be to remove the radio and check , dont reinstall radio if you plan on getting the adapt kit.
Dec 23, 2011 | 2006 Ford Escape
I purchased a used 2005 Pacifica and often have problems with mice getting into the actual "inside" (interior) of the vehicle! Is this very common? I have driven cars that are 20 yrs old that...
Look under the car its used maybe someone did some work under there and all it takes is a hole the size of a dime for mice to get in. A drain plug not put in a hole drilled back behind the taillights if they towed a trailer maybe left out a plastic plug for rear quarter.I would say if you had a radio and antenna put in its not the car did you spend 300 on a radio for a middle of the road or did you buy a cheap one for 150.How do you know they hooked up the new antenna? Did they pull up the carpet drill a hole for the antenna wire take the dash apart to run it I doubt it. They probably mounted the antenna and hid the cable and hooked up the old antenna. Follow the new antenna cable that it comes through the body goes under the carpet and comes up into the radio area. And if they put a hole in the body plug it to keep the mice out
Jul 26, 2011 | 2005 Chrysler Pacifica
Cant get radio to play stops on station wont pick up antaina hooked up
Check if the antenna male plug is completely plugged into the antenna port of the car stereo.If it is plugged well in the car radio but don't pick stations then your antenna cable is bad.You need to install a new set of antenna,available at any car audio supply.
Jan 30, 2011 | Sony Car Audio & Video
How can I reconnect my antenna. The paint shop
open front door you should be able to grab antenna cable with a wire clothes hanger.fish wire through grommet behind the kick panel.pull radio out fish antenna wireunder dash to radio opening and then plug into back of radio antenna jack then reinstall radio
Feb 18, 2010 | 2002 Dodge Caravan
2003 santa fe radio not working
if you are getting static, you need to replace the antenna. you can also add an antenna booster.... but chech the connection of the antenna inside the radio to make sure it is still connected.... if you have the origional radio for the car connect that back up and plug the antenna in on it and see if you get the tunes, if you do then it is a wire problem in the new radio with the antenna wire itself....hope this helps you out
Jun 16, 2009 | 2002 Hyundai Santa Fe
Connect sirius fm adapter to 2008 honda civic sedan radio
You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
This way you can switch it on any station to get rid of the static.
You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
Jun 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
62 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
