Question about Sony PlayStation Portable (PSP) Console
Sony psp scrolling
My psp willnot stop scrolling down the menu unless i keep pressing the right or left button it does play but is very difficult to.
  • neonzidane3 Jul 17, 2008
    my PSP's analog stick also scrolls down nonstop..
    i searched for repair parts and found something at videogamecentral where it says "Replace any Part on your PSP! From screens to sticks..do the repair yourself."
Change your analog stik.
Posted on Jan 14, 2008
When i play game iso/cso the game will lag..i use 5.50 prome-4..it is not game problem bcoz it never happen bfore....spry for bad english.. thanks
Hi.
Try this;
1. Enter into XMB menu by pressing "select" button while on main screen. 2. Scroll down to CPU Clock Speed (second from top) 3. Press scroll right until you see 333/166 on its value
Try playing games again if this solved your problem...
May 31, 2011 | Sony PlayStation Portable (PSP) Slim...
How to connect ur psp to internet
Requirements: 1 Router, 1 psp. 1. Make sure your psp WLAN switch is on. It is located on the top of the newer psp's, or on the left of the older ones. 2. Go go to the psp menu, then go to the left tab on the left. Scroll to the very bottom of that menu. 3. Click "Network Settings", then "Infrastructure Mode" click that. 4. Click "[New Connection]", then "Scan". 5. Now it will show a list of Routers and or connections. The "SSID" name will be of your router.(Make sure the signal strength is 70% or better! And also that the Security is "None" Unless you know the security code.) 6. Press right or X when it shows the SSID menu. 7. Press right or X on the WLAN Security Settings (DO NOT CHANGE THIS OPTION!) 8. Press right or X on "easy" unless you have knowledge on networks. (If you do not see this then you have a security code, if so put it in on that menu then you will see this one.) 9. Press X on the "Connection Name" to edit it, change the name to some thing you will let you know its your connection. Then Press the Start button when done with the name. 10. Now it will show you a overview of your connection settings Press right or X to save and test it. 11. Now you have internet when you connect to it click the connection name you chose!
Mar 14, 2011 | Sony PlayStation Portable Slim Black...
How yo download psp games
First, you have to find the game you want, and download it to your computer.
  1. 1 Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  2. 2 To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  3. 3 Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  4. 4 Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
Hopefully, this works for you!
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
Got lead to connect psp to pc to download music to psp thought would work automaticly but i go usb mode on psp but cant link them help please
Hi deanocar,
Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. --> Alsomake sure the Memory Stick PRO Duo has been formatted for PSP. If it's not thisis how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3.Press the "home" button on the PSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 18, 2011 | Sony PlayStation Portable (PSP) Console
My psp files gone
I assume you have a PSP with customize firmware.
1. Turn on your PSP and press the "SELECT" button and the VSH Menu will appear.
2. Scroll down to USB Device and change the setting into "Memory Stick".
(Use the up & down directional button to scroll and use the left & right directional button to change the setting.)
3. Scroll down to UMD ISO MODE and change the setting to "SONY NP9660".
4. After you change the setting EXIT to the main console and restart your PSP.
If this solution did not work come back and we will try other solutions.
Jan 21, 2010 | Sony PlayStation Portable (PSP) Console
Psp 300 doesn,t show the usb mode when connected to PC.It keeps showing Please wait .No problem with usb cable,port.
Hi rimoricky, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 16, 2010 | Sony PSP-3000 Silver Console
Will not make connection to computer
Hi jandk41787, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Sep 07, 2009 | Sony PSP (Piano Black)
My psp cannot connect via usb mode
Hi rin1_02, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Apr 07, 2009 | Sony PSP-3000 Silver Console
From psp connecting to computer
Hi smsrahman60, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 23, 2009 | Sony PSP-3000 Silver Console
PSP
Try to restore defualt settings: scroll left to settings in menu, scroll down to system settings, press "x" and find restore defualt settings(press "x" and will restart again.
Jan 28, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
308 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
