Problem for TV Combos
Generic problem for all TV Combos
Connecting my TV and DVD player to a dig...
I have a Tevion 32 LCD HD TV and recently bought a DIGITEL HD digital STB. I think a cable is missing, or I need to purchase one because I can't connect it up and get it to work/receive a digital signal. The STB came with two sets of coloured cables but no S-Video cable or a HDMI cable (unsure if I even need those).
The TV contains an integrated digital tuner.
I'm pretty techy but need some help here...
Solution #1
posted on Nov 23, 2009
Rank: Guru
Rating: 87%, 70 votes
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Popular Solutions for TV Combos
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
2 Solutions
Toshiba MW24FM5 24 in. TV/VCR/DVD Combo
1 Solution
Broksonic CTSGT8118T 13 in. TV/VCR Combo
1 Solution
Questions and Unsolved Problems for TV Combos
technika 19 dvdid 107 dvd player does not work leds on dvd player not lit
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
My pana 36" hd tv runs my cable system fine, but when i change to change it, or to run a dvd...
(More)
(More)
My pana 36" hd tv runs my cable system fine, but when i change to change it, or to run a dvd player on it, it wont. Cant change the basic channel from 4, and.. when i try the various video compnents, none pick up the dvd
Posted. Thank You!
television cable input jack pulled out.TV has power to but no picture,blue light indicating power...
(More)
(More)
television cable input jack pulled out.TV has power to but no picture,blue light indicating power lights up but no picture.
Posted. Thank You!
When I turned the TV on the screen shrinks to a straight horizontal line about 1" thick across...
(More)
(More)
When I turned the TV on the screen shrinks to a straight horizontal line about 1" thick across the screen
Posted. Thank You!
Sylvania LC320SLX turns on, (digital TV) shows on screen, then TV turns off?
Posted. Thank You!
