Question about Sony Ericsson K800i Cellular Phone
K850i screen i got a k850i 2 months ago. my screen is failing. it started with 2 blue lines down the right hand side and now the whole screen has last detail. i can just about read all icons etc. i tried a master reset and nothing happened,, any ideas what i need to try next
  • Pedro100 Mar 08, 2008
    The screen on my k850i cracked where one of the touch sensitive buttons is, the screen is not damaged on the outside - I suspect a design weakness (Continual pressing and touching cracks the screen on the inside). The Phone operator would not repair under warranty :( very disapointed:(
Hi,,
Pls i have a K850i i am using it since 40 days,,this morning the menu touch botom start playing funny,,sending messege by it self,,changing things any how,,pls advise me what to do...Thanks
Posted on Mar 10, 2008
    Problem Solver:
  • 16 Answers
Hello
if you only bought it 2 months ago it will be under warranty
you should send it back to be serviced as it sounds like a faulty LCD and it will need to be replaced
Posted on Jan 15, 2008
When i turned my camera on I got a large image of a crack expanding from the lower right hand corner of the screen. Most of the screen is black and the cracks are lit up white. There is a blue patch of...
Sounds like a cracked screen. My Rebel t1i looked the same way when i dropped it a month ago. Not sure of cost to repair i never looked into it but probably not cheap.
Apr 08, 2011 | Canon PowerShot G9 Digital Camera
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Fuzzy line going right down right side of Sony Laptop VGN-CS26g
The pixels inside of the LCD are going bad. Your screen is going to need to be replaced. When pixels in screens go bad it usually turns colors or gets fuzzy after it heats up.
May 14, 2010 | Sony VAIO VGN-CS260J/P Laptop
Vertical Line on Lap Top
One or both of the following:
Your signal processor is failing OR the lcd display panel itself is failing. When one fails it's prudent to replace both.
Jun 04, 2009 | Compaq Presario M2000 Notebook
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Mar 23, 2008 | Televison & Video
Sony Ericsson K800i Cellular Phone Logo
132 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
