Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover SteamVac Is there a spring in the trigger. The valve was is two pieces and we glued it together and it still won't retract. Is it possible there was a spring in the trigger that got lost or do I need a new valve? redevil16 helped me last time. Hopefully he or someone can help. Thanks, Sandy
  • 126 Answers
I'm not sure what your referring too, but Here is how it works. The trigger is snapped into two "rocker retainers" in the handle. when you pull on the trigger, it rocks and pushes on a rod that goes down to another shorter rod and that one pushes on the valve that releases the solution. A common problem was that the "rocker retainers" would break off and the trigger would not push on the first rod so the machine would not release solution. You will have to replace the handle half (called a trigger guard). The trigger itself has two plastic "springs" molded into it. This is all one piece with the trigger and they don't usually break. Also, when you remove and replace the handle, you have to pull the trigger to re-engage the two rods togeather or the machine will constantly spray solution. I hope this helps.
Posted on Jan 13, 2008
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover max extract leaks from end of upholstery hose
Hello! The nozzle/valve assembly, the white piece at the end of the hose that releases the solution may be clogged with build-up residue. Try soaking the trigger end in warm water for a few hours. If this does not help, the nozzle/valve assembly may need to be replaced. Order the nozzle/valve assembly by following this link. Search Results or order the complete hose assembly by following this link. Search Results
Hope this helps!
Jun 06, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Spring fell of of trigger handle
Go to this site and you should be able to see exactly how everything goes together, and if you need new parts, this place will sell them to you for next to nothing....
http://www.ereplacementparts.com/hoover-f6215900-steamvac-agility-parts-c-37315_37419_37432.html
Let me know how it all goes for you, ok?
Nov 24, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
http://www.govacuum.com/hoover-steamvac-dual-v2-tank-valve-part-43513015.html
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
GoVacuum
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
I think the trigger on my upholstery hose is broke how can i tell? trigger is loose- water just flows out and i have to shut the machine off. i have a hoover steam vac dual deep cleaner
The most common issue with this is the white nozzle tip broken. sometimes it comes out. it still could be the trigger. take it to a shop and they can tell right away. the trigger is spring loaded, you should feel tension.
Oct 09, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac hose won't spray water
SOLUTION#1 If the attachment wont spray water, the white plastic nozzle tip may be clogged. Take the brush attachment off, remove the two screws from the gray retaining cover (BE CAREFUL THE WHITE TIP UNDER THE BLACK PLASTIC TRIGGER MECHANISM IS SPRING LOADED and WILL GO FLYING). The trigger mechanism can be taken apart by lifting the black part off (may have to slide it back slightly), remove the spring from the white plastic valve insert, then take a flat screw driver and carefully pry the two white pieces apart and blow out both ends. You may have to find a hair size piece of wire to push threw it to clear it. The whole process is really simple once you take it apart and see how it works. Putting it together is in reverse order. The white piece will only go in to the black part one way and with the spring on you need to push it through the hole and the trigger part hooks on, slide it back on to the hose, then while holding it all, and put the gray retaining cover back on. Sounds more difficult than it really is. If your not mechanically inclined take some pictures as your taking it apart to refer to.
Solution#2 If the nozzle and trigger are clear, with the trigger assembly off the hose, plug the hose into the shampooer and turn it on (if the hose inside the suction hose is clear you should start seeing water flowing out the hose. If not run a piece of wire through that hose to unclog it. If its still not flowing then the Pump on the unit needs to be replaced.
Solution #3Cost Around $20 with shipping online. Google your make and model, and upholstery attachemnt pump. Mine was called AP4561692 (43582018) PUMP ASSM, from http://www.appliancepartspros.com/. (there real good about the live chat and helping you find the part).There are Youtube videos on taking apart the shampooer, which is pretty easy. The one place that might give you problems after you get down to taking the pump off, there is only one screw holding but there is on the bottom side of the pump a black bump that clips in to the base of the shampooer and you need to stick a screw driver from the bottom up and pry the base one way and pull the pump the other to unhook it.
Jun 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
Hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
May 15, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Trigger not working
Sounds like you need to replace the handle valve pieces, if they are available, if not then you will have to replace the hose asm. Just take the valve off and see if one of the pieces have a piece broken off. Then with your model number, you can see if that piece is available from someone that has Hoover parts.
Jan 07, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
328 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
