Question about Kenmore 62602 Electric Dryer
Kenmore ultra fabric care dryer runs, but does not heat up
  • 15 more comments
  • Anonymous Jan 31, 2008
    Dryer Runs but does not heat up
    Cleaned under filter
    Made sure dryer vent hose was clear
  • TimelssR1 Feb 05, 2008
    My Kenmore jsut recently had the same issue occur...it runs, the tub spins..but no heat!
  • michelle smy Feb 10, 2008
    dryer runs but i have to turn it on and run 3 cycles before the clothes are dry
  • reeney Feb 19, 2008
    my kenmore dryer is having the same trouble. it runs but doesnt heat up.
  • Panado Mar 15, 2008
    Funny how so many of them break down at the same time, anyway - opened ours up, had to replace the Thermal Sensor switch, available at SEARS for about $23. Open the front panel below the door with 2 flat screw drivers and then remove the heater box on the right hand side.
    the parts are on the left, simply replace and you are back in business.
    Good Luck
  • Anonymous Apr 12, 2008
    my dryer runs normal and it doesn't have heat either, urg
    amy
  • ivychamei Apr 12, 2008
    dryer runs but dose not heat up
  • Anonymous Jun 04, 2008
    Heh... same here... I've had mine for 3 years... but I'm guessing it's an early-mid-90's model?
    Thanks for the tip on the thermal sensor.. will go get the part.
    -Brian
  • Anonymous Jul 25, 2008
    runs but doesn't heat
  • jbschroeder Aug 20, 2008
    Kenmore Ultra Fabric Care dryer ( electric) runs but does not heat.
  • janetwlms Oct 19, 2008
    I have exactly the same problem but could you be more specific as to how to fix this? Thanks
  • Anonymous Oct 21, 2008
    dryer runs no heat
  • geo13 Oct 21, 2008
  • Anonymous Jan 09, 2009
    my dryer tumbler works but dryer does not heat
  • Anonymous Apr 14, 2009
    Kenmore dryer runs, but does not heat up. It is an electric dryer. I can find no model number on the dryer. Labeled "Kenmore Ultra Fabric Care Heavy Duty Soft Heat"
  • darcpoet May 11, 2010
    kenmore dryer will not heat up it is a gas dryer can you help me
  • lenwiz May 11, 2010
    Dryer runs but does not heatup or dry????
  • 185 Answers
Check the thermal fuse the operating therostat and the igniter is this a gas or electric dryer
Posted on Mar 25, 2008
  • 156 Answers
Bad thermastate on the heater box comes in set with the fuse are element is bad as far as running not drying clean the vent out
Posted on Mar 19, 2008
Where is the fuse?
Posted on Jul 30, 2012
I dont have a slolution; i have the same problem but my dryer is gas.
Posted on Sep 13, 2012
imufo2
  • 3773 Answers
SOURCE: where is the thermal fuse
Remove the back panel. The thermal fuse is located at the top left of element case.
Posted on Sep 12, 2010
gittos73
  • 244 Answers
SOURCE: kenmore ultra fabric care
only thing i can think of without being there and able to test parts is your door catch could be faulty
Posted on Aug 11, 2007
  • 32 Answers
SOURCE: Kenmore ultra fabric care dryer runs, but does not heat up
could be a thermal fuse,heating element or a heating element relay.if you pop the trim caps off of the sides of the console,and remove the 2 phillips screws in the corners and lift up console you will find a tech sheet inside.if you have a multimeter that you can check continuity with along with the tech sheet,you might be able to figure it out..good luck
Posted on Sep 29, 2008
SOURCE: no heat coming out
It will either be a blown element or possibly a fan belt broken on the back under the plastic cover.Hope this helps Cheers.
Posted on Jul 30, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Posted on Mar 28, 2010
Electric Dryer wont heat up
Dryers don't have fuses, I would say the heating element has went bad, not to hard to change
Sep 27, 2012 | Kenmore Dryers
Kenmore-ultra fabric care gas dyer runs but no heat..gas is on..help
It is most likely the thermal fuse watch this video your unit is made by whirlpool and these are very common to fail http://www.youtube.com/watch?v=ajDWK7x1J5Q
Jun 20, 2011 | Kenmore 62602 Electric Dryer
Kenmore Ultra Fabric Care dryer Model/stock number 96595220 65952 Dryer shuts off all the time. Runs, heats, works, then just stops. This happens repeatedly. Please help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Kenmore 659 Electric Dryer
heatman101
Mar 25, 2010 | Kenmore Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore ultra fabric care dryer runs, but does not heat up Same as Christy's. Runs no heat, however, the exhaust vent is clear. Could this be the fuse or heating coil?
Sep 28, 2008 | Kenmore 62622 Electric Dryer
Kenmore Electric Dryer
check your fuses.one runs the dryer and other heat the dryer.
check to see if belt is broke or wire is burned off of motor.
Mar 08, 2008 | Dryers
Aug 10, 2007 | Kenmore 659 Electric Dryer
Kenmore 62602 Electric Dryer Logo
8,277 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
