Question about Nu Mark Numark Cdx Table Top CD Player CD Player
CDX NOT RESPONDING
I turn it on and I can't recognize anything on the display. The display says 19; m\ +WF. All other buttons are none responsive, Turn Table turns but delayed on stop. Does not play any disks., the screen just starts acting up even more doing things i can not describe. PLEASE HELP!!!!!
  • 4 Answers
Sounds like the operating system has crashed somewhat.... Is it still operational enough to read a firmware update disc?
Posted on Mar 27, 2008
  • DJ Steve Sep 10, 2013
    Well im able to work mine. I have to leave it un screwed :( so air can get inside and keep the components cool. What a waste Im sorry i went to Numark to get dj Hardware
    when it over heats the display gets wacky
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
My Drayton seven 7 day central heating control ( fitted in 1990) is not responding properly. The clock is working, but none of the buttons are responding. I have changed the battery. I no longer have the...
Hi, thermostats fail and need to be replaced from time to time. If you get no response when you try and program this stat, and you have a display, the stat is faulty.These buttons are contacts on a circuit board that wear out and this is what has happened to yours. Its 21 years old, and I would say you have had real good luck for it to last that long. Replace it and you will be back in business.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Heating & Cooling
Buttons don't work or are not responding on my LG Shine
I am Tenzin. And your solution is change your sliding chip. it cost in indian rupees as 900rs. but u ask first. i am sure that my method will help you.
Apr 29, 2010 | LG Shine KE970 Cellular Phone
Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Apr 17, 2010 | Sony CDX-S2210 CD Player
My sony cdx-gt130 xplod car stero won't show me my volume or anything else. all is does is blink through saying stuff like "fm/am" and the other random stuff. how do i get it able to start letting me being...
Press and hold the SELECT button. (the setup display appears) Press SELECT button several times until Demo appears. Rotate the volume knob to turn Demo to off. Press and hold SELECT. This will return the unit to normal operation / display. Page 9 of this link to your Sony CDX-GT130 operating instructions. This guide encompases 4 similar models; CDX-GT330, CDX-GT33W, CDX-GT230, and CDX-GT130. Please note differences where indicated.
http://www.docs.sony.com/release/CDXGT33W_US_ES_FR.pdf
Dec 04, 2009 | Sony Car Audio & Video
Stuck on but not playing and no button response
When the EAX screen appears tap it hard on the right side, just above the menu button.  Seriously, it works.  I had to tap several times, finally really hard, but the machine came back.  Many others have posted this tip.
Sep 10, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
May 30, 2008 | Sony CDX-M8800 CD Player
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Sony CDX-M630
not open the face? or not get on the stereo? if not open the face maybe is too fit on the space for the stereo, check down if have space, if dont get on, check if are well conected
Nov 02, 2007 | Sony CDX-M630 CD Player
Front Display Panel Not Responding
the cable is torn that connects the lcd to the headunit.
Jul 01, 2007 | Sony CDX-M8800 CD Player
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
171 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
Marvin
Marvin
Morne Olivier
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
