Question about Sony Handycam DCR-PC5 Mini DV Digital Camcorder
Sony DCR-PC5 Upon turning the power on the camera beeps 9 times then flashes the code C:31:23. What does this mean and how can I fix it? Please help!
  • mavlianv Sep 23, 2008
    eject sign on lcd
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 17, 2008
I need to down load drivers of mini DV sony DCR-PC5E
  1. look at manufactuers website
  2. look on google (not recommended
Aug 10, 2010 | Sony Handycam DCR-PC5 Mini DV Digital...
Dcr pc5 camera to computer connection
Your PC5 should have FireWire as standard, but Sony use a smaller 4 pin connector which looks a little bit like the tiny USB connectors on modern phones and still cameras. The main difference between the 4 pin and the standard FW400 6 pin, is no power is supplied to the 4 pin, so the camera must be powered from the internal battery or an external supply
The original Imacs came with such a cable, but you can buy these from various suppliers. It's part number F3N401-06 from Belkin or M8706G from Apple
Dec 29, 2009 | Sony Handycam DCR-PC5 Mini DV Digital...
Everytime i insert the tape i get this beeping sounds and flashing numbers on the screen.
Beeping and error code flashing shows that camcorder got some problem and usually its tape mechanism that needs qualified tech to check and fix.
Mostly its take-up reel section problems. Local camera tech will fix it.
Thanks.
Nov 12, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
"SONY 'InfoLITHIUM' SYSTEM" Error
when I opened up the camera, the tape part of the cassette was hanging out. I tightened the tape and reinserted the cassette. this seems to have fixed the problem. hope this helps.
May 07, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sony Video Camera Recorder
what does c31.23 mean when showing on the screen.can i fix the problem myself or do i have to get a professional to fix it.when i try to use the video a beeping noise and the above number is displayed on screen
Jul 07, 2008 | Video Cameras
DCR TRV22 does not showup initial screen
What is the message/ error code flashing in your camera?
Jun 25, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
Connect Sony Handycam DCR-PC5 Mini DV Digital Camcorder to my Laptop
try to install the cd software of your sony handycam into your laptop..
hope it will help thanks...
May 27, 2008 | Sony Handycam DCR-PC5 Mini DV Digital...
Cassette compartment
I had same problem. Cost me $200 to fix at local repair outfit.
Dec 23, 2007 | Sony Handycam DCR-PC5 Mini DV Digital...
Sony camcorder CCD-TRV118
the cameras power may need to be reset
Turn the camera off and remove the battery and the power chord
wait for a bout sixty seconds
put the battery back in and try to start it up
Dec 11, 2007 | Sony Handycam DCR-TRV118 Camcorder
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all Sony Handycam DCR-PC5 Mini DV Digital Camcorder Questions
Sony Handycam DCR-PC5 Mini DV Digital Camcorder Logo
253 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
