Question about Rockford Fosgate P6001BD Car Audio Amplifier
Amp i have a rockford fosgate p6001bd amp and the protect light came on when a fuse blew so how do i turn this off? is there a reset button
  • 631 Answers
There is no reset button. If you disconnect all of the speaker wires from the amplifier's speaker terminals and unplug the RCA cables, does the protect light still come on (I assume that you've already replaced the fuse)?
Posted on Jan 13, 2008
Protect light
Could be shorted output devices or an open trace on the board.
Sep 07, 2013 | Rockford Fosgate P6001BD Car Audio...
My rockford fosgate T1 amp blew a fuse and now protection is on
Chances are that more than a fuse went. I would follow (internally) the path of the wires from the speaker you mentioned - inside the amp. This should bring you out to the main amp. I think you will find that whatever powers that channel is faulty.
Apr 10, 2013 | Rockford Fosgate FAP T1 Amplifier
I was using bridge on a Rockford P300 and blew my cheap speakers but now my bridge doesnt work. Bought new speakers and want to run in bridge mode is there a fuse inside maybe or did I blow it up?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
No internal fuses. Your mosfets are toast. A thumbs up would be greatly appreciated if this answer is helpful to you. using-bridge-rockford-p300-blew-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Apr 07, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
Amp not working
It sounds like you either blew a fuse, or you cooked your amp. The fuse on the P200.2 amp is a 30A fuse, and it sits right next to the power, ground, and remote wire connections on the end. Pull the fuse out and see if it's blown. You should also check any other fuses that you have in the car before the amp.
Mar 03, 2010 | Rockford Fosgate Punch P2002 Car Audio...
Rockford Fosgate punch protection light
power it off, then on...check you're fuses. unplug the car battery and try again. good luck.
Sep 05, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
I have a rockford fosgate 501bd amp the protect light comes on when my deck turns on even with no speakers connected
un hook the subs and let the amp sit there on if the protect light shuts off you wired your subs wrong if it doesnt go off tun it off then back on with no sub music all the way down then slowly turn the music up if the light is off then comes on you need new rcas
May 03, 2009 | Rockford Fosgate Power 501BD Car Audio...
Just hooked up fosgate bd1500.1 to 2 JBL gto series 15" subwoofer
Your current alternator is strained and cannot give the required current draw of your amp. Most aftermarket amps have exterior fuses. Try adding these up for a round-about current draw number. I would bet that your amp is killing the availible power from the electrical charging system of your car. You could always go up to a higher fuse, (I run a 200 amp breaker) bu this will only make your stereo work and your alternator fail prematurely. Try searching ebay or go to ohio generator for a stronger output alternator.
May 03, 2009 | Rockford Fosgate Power 1500.1BD Car Audio...
I think my ex blew my amp
model number? im thinking 401s? if so that should be the only light on
Aug 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate P6001BD Car Audio Amplifier Logo
594 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
