Question about Microwave Ovens
Everyone is useing codes and wont tell me so could you tell me some codes
  • 102 Answers
Cook, thaw, reheat or simmer? *yawn*
Posted on Jan 12, 2008
Why won't Samsung OTR microwave work?
thanks a lot for informative reply everyone! worked well for me, sharing it with http://dissertationwritingservices.org/ now!
May 17, 2017 | Samsung Microwave Ovens
Sharp r520kst door wont stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Mar 23, 2013 | Sharp R-520KST Countertop Microwave Oven...
Finding a local service provider
Google it .Repair, your brand and near your zip code.
Jun 18, 2012 | Microwave Ovens
Maytag microwawe model mmv4203dw00 the control board is showing a trouble code e5 unit wont go on i try unpluging from the outlet to reset it but still it wont work
Actually it can't be "dead" if a fault code is on the display.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
It should tell you what the E5 code means, but I would suspect a defective temperature sensor or control board.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jun 06, 2011 | Maytag Appliances Over-the-Range Microwave...
Tappan gas stove manual
There are several hundred.
We must have a model number.
Feb 20, 2011 | Microwave Ovens
Panasonic microwave nn-6372awm memory codes
I HAVE A PANASONIC MICROWAVE,MODEL NN-6372AWM,SOMEONE WAS GOING TO USE IT AND I DON'T KNOW WHAT THEY PUNCHED,BUT IT NOW SAYS LOCK ON THE SCREEN,THE DOOR WILL OPEN BUT YOU CANNOT USE THE TIMER.HAVE HAD IT ABOUT 10 YEARS,WORKS FINE,LOST THE BOOK ON IT.CAN ANYONE TELL ME HOW TO UNLOCK IT.I AM SURE IT HAS A CODE.
Apr 21, 2010 | Panasonic Microwave Ovens
Microwave runs but will not heat
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
The air seems warmer? Probaly generated by the heat of the lamp?
Mar 19, 2009 | Microwave Ovens
Microwave JE1650AA 002 Light, timer, panel display and beeper all work but the microwave nor the turntable work.
Hi worzelh,
When a microwave suddenly stops heating food, but still appears to run (the control electronics and light are usually a separate circuit), it's usually a defective/dead magnetron.
The turntable _may_ or may not be on the same circuit as the magnetron, that's hard to say without a wiring diagram or schematic.
Prices for replacement/repair will vary, you will need to find out what that service costs in your area before having enough information to decide on repair or replacement. If you tell the repairer that you suspect the magnetron, they should be able to quote you a fairly accurate estimate.
When my first microwave lost it's magnetron (~20 yrs ago), it was 5 years old at the time, and the cost of buying a new oven was only a little more than the repair - but I had the repair done anyhow. Since then, we've replaced the entire oven instead (twice). Newer ones may have more power/less energy wastage, etc.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Feb 21, 2009 | GE JE1650AA/WA/GA Microwave Oven
Wont Start, Showed a code 98 I believe
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 21, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
54 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
