Question about RCA TH1101 MP3 Player
Rca pearl 1gb
Screen says "no files" but when plugged back into computer, files ARE in memory. tried updating to 2.0 software, but didn't help. Please save me from tossing it out!
  • 8,596 Answers
Re: rca pearl 1gb
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Posted on May 24, 2008
0 characters
3 Points
My daughter's RCA 'Pearl' MP3 player will power on and the screen will say "Usable memory exceeded, Please remove a few files". It will then shut itself down. Because it won't stay on, my computer won't...
Main support for the TH1102 is on next sites:
To reset the player remove the battery and replace it.
If the player won't function correctly after that, go to the trouble shooting site:
Get a download of the firmware upgrade
direct link PEARL_FWUtility_v2.0.exe , or look on next page:
Connect your player and install the updater onto your computer.
Follow the steps as told within the updater.
Aug 07, 2010 | RCA Pearl TH1102 MP3 Player
RCA pearl 4GB expandable memory?
The card you are trying to use is likely a high capacity sd card (SDHC). This player does not support high capacity cards, it only supports microSD cards that are non-high capacity (I think most of them are usually 2GB or less, but you can find them up to 4GB).
Nov 30, 2009 | RCA Pearl TH1102 MP3 Player
When my computer stopped recognizing my RCA Pearl, I was able to fix the firmware inside the mp3 player even though the computer didn't seem to think it was there.
You mentioned you tried to reinstall the software, & got nothing, but I will walk you through reinstalling the firmware on your player as this is the most likely fix.
You can download the RCA TH1102 software here:
When you start this program, a windows pops up with troubleshooting instructions are the bottom. You can read them, but I will also take you through the steps.
  1. start the program,
  2. remove the battery from the TH1102 & wait at least 10 secs,
  3. hold the play button while plugging into usb,
  4. release the play button the the term "initalizing" replaces "searching",
  5. click the start button to replace the firmware.
Hope that helps.
Oct 10, 2009 | RCA Pearl TH1102 MP3 Player
It says exceeded usable memory and shuts down and wont come back on
I haven't seen the exceeded usable memory message on mine, but I am familiar with Pearls not coming back on.
First, perform a reset buy removing the battery for at least 10s. Sometimes mine just shows the plain pearl logo (not the moving one) and then shuts off. Removing the battery for a while and then putting it back in always fixes it so that it shows the plain pearl logo for few seconds then displays the animated logo and starts normally.
If this fix doesn't work for you, then the firmware inside the Pearl is most likely corrupted, and can be easily fixed by running this software from the RCA website and following these steps:
Hope that helps.
Oct 06, 2009 | RCA Pearl TH1102 MP3 Player
Unable To Format, Or Open, Even LOCATE my RCA PEARL.
1)try your player in another usb port.
2)reboot your computer
3)make sure you have the software and drivers installed for your player.
4)and make sure it is fully charged.
May 31, 2009 | RCA TH1101 MP3 Player
Pearl mp3 player
1. Download the latest firmware.
2. Connect Player to PC
3. Take backup of files
4. Format player
5. Upgrade with the downloaded firmware
6. Copy back the files to the player
May 22, 2009 | RCA Pearl TH1102 MP3 Player
Computer not recongize the rca th1602 mp3 player
The first time I tried to restore the firmware in my Pearl it would not recognize it. I had to follow all the troubleshooting instructions that popup when you run the software. Basically, try taking the battery out and waiting 10 seconds or so. Run the software and read all the instructions at the bottom of the popup window. then hold the play button, plug your player in, and keep holding that button until the software recognizes it. It works.
May 05, 2009 | RCA TH1602 MP3 Player
Need aac upgrade firmware My RCA Pearl 1611 says the exact same thing....need ACC firmware update...I've updated a billion times with no fix. It won't play a thing! To make matters worse, I have 2 of...
My RCA Pearl gave me the AAC firmware message with some files until I followed all the troubleshooting instructions that popup when running the firmware update software. The firmware is at The instructions say to:
run the firmware update software software,
reset the player by removing the battery or holding the power button for 10s for players with internal batteries,
hold the play button while inserting the unit into usb,
release the button once the software changes from "searching" to "initalizing",
check the box to format the data on the player,
and click start.
When I did this update without formatting, the aac fix did not work. I
Jan 03, 2009 | RCA Pearl TH1102 MP3 Player
RCA Pearl TH1602 Frozen?
I had the same problem, usually plugging it into the usb port on the pc and verifying the files on the player, then disconnecting the player will solve the problem. Other times i have to reformat the player, if you do that, you will have to put all your music back on. It's a pain, this has happened to me 4 times, I've only had this thing less than 6 months! It was inexpensive, I guess you get what you pay for, but I like having a AAA battery instead of having to remember to plug it in to the pc to recharge every 15 hrs.
Oct 17, 2008 | Teac MP-111 MP3 Player
RCA TH1101 MP3 Player Logo
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
