Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Washermachine our washer machine comes on and then we choose a program then comes up with test to start a prewash how do i reset my washer machine
  • Anonymous Mar 31, 2008
    I had a power cut today and when the power returned an error code F 09 has appeared on the display and I cant shift it. Can you advise please?
    President:
  • 1,294 Answers
Try pressing the "on" and "start" button together for over 5 seconds.............. the demo code should come off.
You will rate me pl. if helped....................
Posted on Jan 13, 2008
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light is on and cannot get the washer to do anything
DIAGNOSTIC TEST
The washer must be empty and the control must be in theOFF
?Close the door.
?PushCONTROL/ON(if present on this model).
?Select theDRAIN/SPINcycle.
?SelectNO SPINby pressing theSPIN SPEEDtouch-pad.
?PushPREWASH OPTIONfour times within five seconds. (If
PREWASH OPTIONis not present on this model, pressEXTRA
RINSEfour times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push thePAUSE/CANCELtouch-pad,
PREWASH OPTIONtouch-pad two times. IfPREWASH OPTIONis not
present on this model, pressEXTRA RINSEtwo times.
Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not start. The control lock light is illuminated on the washer panel. I unplugged the machine and replugged it in. Washer still displays "control lock" Any suggestions?
DIAGNOSTIC TEST
?Close the door.
display.
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Indications
C:00
C:01
C:02
C:03
C:04
C:05
C:06
C:07
C:08
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer says the control is locked
My dear friend this is an very common problem people do face with.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 13, 2010 | Whirlpool WFW9600T Front Load Stacked...
I have a kenmore elite calypso that does not respond to most key presses, except when pressing "normal" the "whitest whites" button lites, and when you press "wool/silk", the "jeans/colors" lights, "buly...
Is the panel lock on??
Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off.
If this reset does not work - unplug for 15 minutes and re-try.
If unplugging for 15 minutes does not reset the controller -
your Main Controller board or touchpad has Failed.
Upon inspection you may have a visible sign one or the other has a burned component on it.
CLICK HERE to see the controller board.
The touchpanel is available in white, graphite, or bisque. CLICK HERE
The Touchpanel is the culprit on 95% of these machines in my experience.
I believe (hard to remember without having the machine right in front of me) there is a fuse you should check on the Motor Controller board that may have popped when the touchpad started acting up too.
Choose wisely - grasshopper - as purchasing and installing the Touch panel will equate to almost 1/2 of a new appliance with a warranty :D
Thanks for using FixYa!!
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi I have a whirlpool duet front load washer (GHW9100lW1) and the status is stuck on CONTROL LOCKED and i can't change it and the machine is no longer working.
DIAGNOSTIC TEST
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
display.
Dec 17, 2008 | Whirlpool Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
102 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
