Question about Refrigerators
Jenn air side by side refrigerator jcd2289ae
First off this thing has been a lemon from day one. I have had the ice and water dispenser fixed so many times I cant count. Now it wont dispense ice again. The back part turns, but the cork screw doesnt.
REAL PROBLEM
The refrigerator runs but it does not freeze or even cool. Does it use freon and can I put it in myself?
Thanks
    Sergeant:
  • 288 Answers
You will need to put on a couple of clamp on piercing valves in the back.1 on the suction line ,and 1 on the discharge line. It uses R134A and you can put in in yourself. I have heard of some people having trouble buying this, but don't know first hand. it is a HFC and you shouldn't need to be certified, but I cant tell for sure. Oh ya, you will need a set of gauges too.
Posted on Jan 12, 2008
The jenn-air fridge that i have jcd2289ae has stopped working it is tripping the gfi, i have tried plugging it in another plug in but it trips the breaker
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2289AEQ/1266/0165000/M0406284/00012?blt=06&prst=&shdMod= here is a simplified wiring diagram for your unit. It might help you track back the problem.
Before it started tripping the circuit breaker what was your refrigerator doing that was not normal? Usually, before something fails massively it will give you hints it is coming. Did your ice maker or lights stop working? Has the compressor been running an excessively long time?
What trips a breaker is the unit drawing more current that what the breaker is listed at. So something in the unit has shorted to cause this to happen. Although the first thing we check in a situation like this is the compressor circuit it isn't always the cause.
Jun 26, 2011 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
I just changed the ice maker on my jenn aire ref. JCD2289AES. The old one was leaking everywhere and making a big frozen block of ice . It seemed very simple but, it the cube tray is not filling with water...
there is a solonoid valve at the back of the freezer section (externally) which should release 7 seconds of water into the ice tray to fill it..
the most common cause of leaking ice makers is that the valve freezes up if not much ice has been used.. and you simply need to thaw the freezer out overnight (put the contents in a cool box, or wrap it in lots of bubble wrap/newspaper and cool blankets to keep it frozen)
that aside, there is a wire ice-stopper that goes up and down as the level of the ice rises and falls.. if it is in the raise position, the ioce maker won't do anything.. you can gently press it down, and things should start almost immediately.
Oct 02, 2017 | Jenn-Air JCB2388G Side by Side...
Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Locked freezer
Press and hold the lock button for at least 3 seconds
Feb 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn Air JRSD209T
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Jun 17, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Jenn Air Side by Side Refridgerator
You could have a layer of solid ice at the bottom of your icetray which is binding everything up. Remove ice tray and any ice from the bottom. Reinstall and be careful of the connection on the back of the ice tray, you may have to turn it a little to get it to mesh correctly. refill and try. Good luck.
Jan 08, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
449 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
