Question about Philips DVP3340V
Dvd/vcr player is hooked up but not playing...
My dvd/vcr player has the cables hooked to the front of my TV (no cable hookups on the back of the TV)
I got the TV to show me the set-up menus and I got the clock set etc, and the vcr tape played very nicely.
My problem is: Now I can't seem to get to the GAME screen again, which is where I was when the tape played for me.
Am I supposed to have the TV set on a specific channel.
We do not have cable or a satelite dish.
I am very confused about this whole thing.
    Problem Solver:
  • 9 Answers
Yes. You definitely need to set your TV on a specific channel - GAME, in your case. Check your TV manual how to get to that GAME channel.
Posted on May 18, 2008
I would like to connect a DVD player to my Quasar TV/VCR combo. No clue.....
Look in the back or the front of ur tv have a (Video Audio holes In).Look in ur DVD player in the back or the front have a (video Audio holes Out).Used a component AV video cable hook both devices together.Find the Video Mode in ur tv 1 or 2,now play the DVD player with a dvd disc.Now u should be playing the content of the dvd disc.If u don't have a AV video cable,tries websites like Amazon.com,Ebay.com to buy a set of AV video cable.
Dec 10, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Cable box-dvd/vcr- tv hookup problems
    buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
    May 17, 2009 | Philips Magnavox DVD/VCR Dual Player
    TV & DVD HookUp (No Box) Can't get picture
    As far as I know, my Go Video machine when there was no box involved...
    The cable came from the wall to the IN of the Go Video box. Then another cable coming from the OUT of the video box and to the IN to the TV. TV should be on channel 3. As far as I can remember, I don't need to push the TV/VCR button, but instead, have to channel down to below channel 2 on the TV to the LINE/INPUT selection. Once you go there, and the Go-Video machine is on, you should be able to see a clear picture.
    You'll push the TV/VCR button if you want to toggle back and forth from the VCR picture to the TV picture (which will be technically blank since it's on the 'line input selection.)
    Hope that helps.
    Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
    Trying to hookup and play standard DVD player
    Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
    Dec 12, 2008 | RCA F25441 25" TV
    Dvd/vcr with ** hookup for cable tv
    Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
    Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
    Trying to Install
    Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
    Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
    Connecting VCR/DVD combo
    Put the Tv on Channel 3
    Jul 11, 2007 | Sanyo DS25390 TV
    How to hookup dvd.vcr to tv
    first of all the the VCR has two connection from the tuner at the back one has out to tv the other has in from antenna you connect the wire from the cable company to the in from antenna.you connect another from the out to tv to the tuner connnection of your tv.and you are on.to connect the dvd to your tv.the tv has either at the front three female connector basic colors red white and yellow.the red and white is for audio in, left and right, and the yellow is for video in.the dvd has similar connections but they are output just connect them matching them color to color.there are some female connectors on the back of the dvd if you want to use surround sound.or play it through a reciever.good luck.
    Mar 26, 2007 | Symphonic WF803 DVD Player/VCR
    Philips DVP3340V Logo
    127 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
