Question about Sharp 17" Monitor
I have a kyocera kc 100 viewer and it wont wake up the pc monitor can ya help?
I bought a thin computer monitor for my mom to use with the kyocera kc100 viewer, but I can't get the monitor to recognize the s-video signal - so the monitor stays in sleep mode. We were really hopeing to go with the thin monitor because she really does not have the room for a tv screen beside the viewer. I tried everything to get the monitor to get out of sleep mode - and there were no options on the monitor set up screen.
Can I apply a voltage signal to the monitor by patching into the vga/s-video adapter wire and use a low volt power supply to get the blasted monitor out of sleep mode? or do we need to buy a tv to make this work?
any suggestion would be greatly appreciated.
  • 1 more comment
  • Terry Karcher Jan 12, 2008
    I bought a dell computer monitor and put a s-video to vga adapter - from radio shack - on cord to the monitor. and I was wondering that since the manual for the kyocera viewer lists tv monitor hookup instructions - that a monitor may not work.
    I bought a s-video to vga adapter at radio shack - so I could hook the s-video cord up to the monitor. the monitor is a dell flat screen computer monitor. the model is a dell 172fpb. I'm wondering if I have to jusy go with a tv to get this to work - because that was the only thing listed in the instructions for the viewer.
    Thanks for your reply
    I don't have or know where to get a converter - but if you would give me a hint on where - I'll get one - thanks
    President:
  • 1,944 Answers
As far as I know, your Sharp screen doesn't have a S-video input. How are you inputting the S-video signal to the screen? The fact that it doesn't "wake up" probably means that it isn't receiving a signal.
Posted on Jan 12, 2008
  • Damen Wong
    Damen Wong Jan 12, 2008
    Did you make sure that the video convertor is turned on and working? If it's those 2 way convertors (that converts both ways) make sure it's set on converting s-video to RGB with input from your viewer and output to your monitor.
  • 589 Answers
I'm confused as to how you're connecting this with s-video. Are you using an RGB / s-video adapter?
What is the exact monitor brand / model?
Pc sleep mode wont wake up
Try plugging in another working screen with a new cable, and if it didn't work then it might be your Graphic card (built in) (and does your screen work only when u turn on your computer for 5 sec or all the time its black screen?)
Jul 02, 2013 | Computers & Internet
I have an old Dell computer monitor that is hibernating and can't be waked up. When I try to wake it, I get an Information Box that says "Monitor is in Power Save Mode. Activate by using the...
click the mouse, move it about or press a key , if that doesn't wake the pc up, then press the power button for 1 sec, that will wake it up
Apr 14, 2011 | Dell Computers & Internet
Monitor has power to it and signal from computer but is asleep and wont wake back up
Is it showing any flashing indicator lights?If not:
....You have to try a different vga cable if it is not built into the monitor, and make sure the pc will drive a known working monitor ok from the same port. If the pc is ok and there are no fault lights showing I would suspect the vga cable
Jan 25, 2011 | Computers & Internet
I'm having problem with my 16 inch CHIMEI LCD monitor flat screen, first when i booted up my computer it was fine, then i just defrozted my computer(because my computer has a deep freeze program)and then...
in my opion deep freeze (pige head)is not good progrram .itt creat big problem. we should know well how can be use it. once a time u should reinstale it or formate ur computer,i hae facing many problem from my custmer. -----thanks
Jun 14, 2009 | Chi Mei Corporation 221A Monitor
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Monitor wont stay on
its basically depend on which type of drivers hadbeen installed. 1st u install it again & if it doesnt work there might b a system problem. feedback the current working position of ur pc & other details if u possible. nothing to worry.
May 08, 2009 | HP w19 19" LCD Monitor
Power button in-op
Not a good idea if your unit is under warranty. You should take it in to a service center for the repair. The unit has many tabs that lock the case to the frame and you could damage them if you do not know how to release them properly. This could void your warranty and ruin your case. The results maybe that you are unable to close it correctly and align it with the frame, to secure it.Unless you are very experienced and have the correct tools to work with. It is better to take it to a service center. Hope this helps.
Mar 27, 2009 | HP Compaq WF1907 Monitor
Keyboard keys
Did you ever find out how to wake itup? Im having the same problem and the monitor wont wake for me
please help!
Jan 19, 2009 | Acer NSK8458AN Keyboard
Sharp 17" Monitor Logo
194 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
