Removing ink from Tumble dryer drum
We have ink stuk to the inside our our tumble dryer after one of our kids left something in their clothes. Now we an't use the tumble dryer because it stains everything with ink residue.
Any suggestions on how we might be able to get rid of the ink?
Try cleaning it off with alcohol.
Posted on Apr 05, 2009
Hi, I wish I knew as we have thew same problem with our washing machine, hope you solve your problem, Sue.
Posted on Jan 14, 2008
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Have a 6kg hoover tumble dryer making noises when on sounds like something trappped under drum
it sounds like your bearing are gone you can buy a bearing kit its not an easy job but if your a handy man or woman it can be done
Jul 29, 2014 | Hoover VHC391 T-80 Dryer
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Tumbler is making wierd sound but the drum still turns and it gets hot
drum rollers/glides, may be the idler pulley:
ttp://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Miele T8005 Tumble Dryer
Tumble dryer overheating!
It could be a faulty thermostat, or the high/low heat switch is faulty, it will be one or the other.
Hope this helps.
Jan 17, 2010 | Dryers
My husband included a pen with his clothes. There is black ink all over the inside of the dryer. suggestions?
Shoot your husband.
Just kidding. Most of the ink can be cleaned with alcohol. If it doesn't then try some ink remover solutions or use lemon extract. You may even want to soak a cloth in lemon extract and place it in the dryer in tumble only cycle to let the dryer do some of the work.
Hope this helps. Make your husband do all the work!
Good luck.
May 17, 2009 | Dryers
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Washing Machines Logo
214 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
