Question about Philips Philishave HQ7780 Electric Shaver
Shaving head check indicator still flashing after installing new heads
The shaving head check indicator still flashing red after installing 3 brand new philishave heads - Part number HQ177, genuine Philishave heads.
any suggestions - have tried the demo cycle.
  • 2 more comments
  • Anonymous Mar 13, 2008
    My 3 year old razor needs battery replacement. I've opened it and found that the twin battery was fastened to the base. I'd appreciate to know whether is clipped or welded to the motor pods. Thanks
  • Anonymous Apr 15, 2008
    Yep, same problem here. I take it there is no soloution to this problem?
  • Anonymous Mar 21, 2014
    shaved ok yesterday, today will not operate, also no charge indicator indicating wanting charge
  • Anonymous Mar 25, 2014
    I dropped the shaving head, the blades fell out. I reassembled the heads, tried out the shaver to find the heads will not rotate. When the start button is pressed, a click is heard but no rotation.. When shaving head hinge is open, the spindles rotate without any problem. Any ideas?
Apparently you need to change the heads within two weeks after the red LED first starts to flash, otherwise the memory chip inside needs resetting. This also poses a further question. How does the unit know the heads have been changed or not ?
Posted on Feb 09, 2008
A red light is on at the lower-right corner, with a shape of the heads. does it mean it is time to relace the heads? how does the machine know?
It's menas that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving heads.
Jul 30, 2011 | Philips arcitec 1060 Electric Shaver
A red warning light is flashing...looks like the razor heads icon...what does this mean??
It's means that you should change new replacement heads, that Norelco RQ10 shaving heads for Norelco Arcitec Electric Shaver heads replacement parts.
Jul 06, 2011 | Norelco Arcitec Electric Shaver -...
What does a flashing red light at bottom of display when you turn razor off mean looks lit the 3 rotary blades
It means they want you to buy a new shaver head. U dont need too, and the light will automatically go off after 7 shaves from when it first came on.
Mar 06, 2011 | Norelco Arcitec Electric Shaver -...
The red light showing the shaving head remains on and the shaver discharged the shaver is one year old
Philips suggests changing the heads every 12 months. The indicator is instructing you that it is time to change them. You will find replacements for model 1060x at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Dec 01, 2010 | Philips Arcitec 1060X
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Whats the symbol flashing on Philips HQ 9190 CC Smart Touch XL
This indicator signals that time has elapsed and it is due for a replacement of the shaver heads. You will find replacement heads for model HQ9190 at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
Once you have installed the new heads, you will need to reset the indicator. You will find this information in your user manual. If you no longer have your user manual, you can view it using the link below
http://download.p4c.philips.com/files/9/9190xl/9190xl_dfu_aen.pdf
Apr 08, 2010 | Philips SmartTouch-XL HQ9190 CC Electric...
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Head Replacement LED still flashing
this is the solution I recieved from tech support from norelco. Here is the conversation: I do not know if that makes any sense or not but will wait and see how it goes.
andy soni: the 3 blades icon keep coming on
Charlie : Sorry for the delay in my response, as I was facing some technical difficulty.
andy soni: I replaced the blades
Charlie : I would like to inform you that though even you have replaced the new heads the indicator stay remain till 2 weeks.
Charlie : The replacement head indicator will remain visible for 2 weeks to remind you that with new shaving heads you will guarantee yourself optimal shaving performance.
Charlie : After 1 week the beeps are audible for 5 seconds. After 2 weeks the beeps are audible for 10 seconds. After 2 weeks it automatically disappears.
andy soni: the head does not flash or anything is that normal it just stays lit
Charlie : Yes, Andy. And it will disappear after 2 to 3 recharge cycles.
Aug 14, 2007 | Norelco Cool Skin 7775X Electric Shaver
Philips Philishave HQ7780 Electric Shaver Logo
1,082 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
