Question about Philips Magnavox 9P6034C 60" Rear Projection Television
CHANGED COOLANT OIL
I CHANGED COOLANT OIL IN MY MAGNAVOX REAR PROJECTION TV MAY HAVE SPILLED LITTLE BIT WHAT TO USE TO CLEAN IT. I PUGGED IT IN AND WONT DO ANYTHING?
  • 1 more comment
  • MCFIX Jan 13, 2008
    I THINK IT WAS CALLED MK ELECTRONICS.
  • danstmp Nov 25, 2008
    i changed coolant and some leaked onto circuit board. Tv still works however top of screen is out of focus looks convexed. I removed circuit board to find about 3 oz. of coolant. how should i go about cleaning it? maybe tv is ruined? i don't know. any help would be greatly appreciated.
    [email protected]
  • danstmp May 11, 2010
    a tv repair store called wheeler tv
Where did you buy the coolant oil?
Posted on Jan 12, 2008
6ya staff
SOURCE:
A little oiled spilled on the motherboard while changing, is the fuse blown or the tv
go to the honey boo boo channel and your tv will be better. Or just get a new tv becuase you spilled oil on yours.
Sep 14, 2013 | Philips 51PW9363 51" Rear Projection...
I have a 60" rear projection tv and the picture looks like its missing a color the picture isnt distorted or anything but the colors are bad what could be the cause and the fix
sounds like a Phillips or magnavox that has bad CRT coolant which needs replacement. If so you can get the Phillips CRT coolant repair kit from www.tvrepairworld.com it comes with instructions and the coolant for all three CRts,
Mar 01, 2013 | Televison & Video
Problem with the Philips Magnavox 9P6034C 60 in. Rear Projection Television, had TV for 16 years. Picture gradually got darker and less clairity
the projection tubes do wear out over time and there is no fix but to replace them. you might first check to make sure the lenses and mirror are clean, do not use compressed air to clean as you may force dust between the lenses. if the picture is darker at the edges or a different hue then the coolant is likely contaminated and needs changed
Dec 15, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 55" rear projection tv problems
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 11, 2010 | Philips Magnavox 9P6034C 60" Rear...
Projection oil spill on main circuit board
The coolant in the CRT's is made up of 70% ethylene glycol and 30% glycerin. The coolant is highly conductive and somewhat corrosive. Since you already tried to turn it on im not sure but hopefully you wiped it up first. Take some 100% denatured alcohol and use that to clean the spill you can just pour it on and wipe it off with the set unplugged of course. then let the remainder on the board evaporate (It evaporates very quickly when open) and repeat the process. if your lucky and it did short the first time you turned it on the fuse just blew.
Jan 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Coolant oil
Anay electronic agent of Phillips , Magnavox etc
Jun 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
UNABLE TO BRIGHTEN PICTURE
Your CRT coolant needs to be changed. Thats whats giving you the dim picture. You can also clean the projection mirror on the inside this often helps. But the coolant will need to be changed to get back the bright crisp picture. Hope this helps.
Jan 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
