Question about Samsung RS2630SH Side by Side Refrigerator
Samsung rs21ncsW
Fridge warming up, I had the same proplem last year and an engineer came and removed a block of ice, from where I don't know as I was not home at the time and my son can't remember?
Please perform manual defrost open both doors and leave 24 to 36 hrs, make sure to leave a lot of damping cloths in the bottom of the fridge. If not resolved require fan replacement.
Regards
Shegar
Posted on Jan 14, 2008
Freezer works great lower part is 50 degrees. why?
When that happened to my fridge the evaporator in the rear of the freezer was a solid block of ice and no air was flowing down the vent into the fridge. A part was replaced and the engineer removed all the ice with a heat gun. Has worked fine for the last 4 years.
Jul 20, 2016 | Frigidaire Refrigerators
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
Samsung fridge warm
check the rubber on doors,if they are good.but you need to let check the liquid
Jul 26, 2012 | Samsung Refrigerators
Model # (P) 55662 serial # (S) 10149733GT Freezer is at 41' and fridge is at 49' and both are climbing. they were at 38' & 48' respectively this morning. * hours ago we tried: ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Kenmore Side by Side Refrigerator
My Samsung model RB1855sl shows the temperatures for the fridge and freezer in celcius. Can you tell me what appropriate temps would be for them to be working? I loaded up with gorceries a few days ago,...
the freezer should be arond -20 degrees celcius and the fridge aroud 5 degrees celcius
There could be a problem with air flow
the fan in the freezer has probably stopped or the air flow into the fridge is probably blocked
You could have a defrost problem. this would allow ice to build up in the freezer blocking off ai flow.
A technician can help you with that
Mar 24, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer cold/fridge warm
You have a defrost issue and needs to be serviced by a qualified LG technician.  The freezer fan motor is blocked by a large chunk of ice behind the rear panel of the freezer section.  You will need to remove the rear panel to get access to the fan and get rid of the ice.  This will get your refrigerator working again but this problem will return.  You will need to have your control board replaced.
May 10, 2008 | LG LRFD25850 French Door Refrigerator
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
87 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
