Question about Brother MFC 210C All-In-One InkJet Printer
Brother mfc 210c printer
Need diagram to remove print head and replace same
  • 82 Answers
Difficult solution !
Posted on Jan 12, 2008
Brother mfc 210c printer problem
try t clean the print head, or maybe you did not use fine ink...
Jan 24, 2014 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean
Do you mean the automatic cleaning option the printer has? Does the printer have a removable print head? If so, you must remove the print head and clean it by letting it sit in a bath of rubbing alcohol or running cold water into it for several minutes. Let dry and reinstall. Or you may need to replace the print head. The nozzles are probably clogged. Does the print job seem abnormal?
Apr 02, 2013 | Brother MFC 210C All-In-One InkJet Printer
My brother mfc j220 canoot print magenta color although on the display the magenta is full i clean many times but when i test print i didnt see dotted magenta. what can i do?
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 06, 2011 | Brother MFC 210C All-In-One InkJet Printer
How can i clean my mfc 210c printer head maually
The majority of the printer parts like take up rollers and gears can be cleaned using Rubbing (IsopropylAlcohol or aka Surgical Spirit in the UK this will remove ost of the finger grease that can build up over time.
I wouldn't however suggest that you attempt to manually clean the print heads as they can easily be damaged and destroy the printer replacement heads can be as much as a new printer and difficult to change.
I recommend using the deep clean function found in the printer driver maintenance tab, you might have to run it 3 times at least if you don't use your printer very often.
Tip is to always leave enough ink in the cartridges to prevent the heads from drying out, this is why most manufactures tell you to replace ink when there is about 5% left in them to prevent this happening
Nov 04, 2009 | Brother MFC 210C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother 210C Printer won't print
I had that problem and overcame it. I think I let it clean a few times and eventually, it worked. I think I also removed/replaced the cartridges.
Brother's solution Center might help.
May 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
Cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Dec 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother printer MFC 210C
by turning the white gear wheelson the lefthandside twice and pushing the ph there by hand. here you can lift it off after you have disassembled the ph cover!
Feb 25, 2008 | Brother MFC 210C All-In-One InkJet Printer
Remove print head
There is no point in removeing a brother print head unless one is replacing it with new, not cleanable totally different print system to most brands. Head burns out heater elements, rather than blocks.
Yes remove every screw in top cover, all cables and post.
print head detached from rail by sliding to left end then back and up.
You are wasting your time trying to clean a brother type print head.
Nov 15, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
82 people viewed this question
James Cagle
James Cagle
Jim Keysor
