Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Viking Range oven door does not close properly
My viking oven door(VDSC48) does not shut properly, and door drops to floor when open. What needs to be fixed, and can it be done by a handyman
  • 1 more comment
  • Jess Fletcher Mar 28, 2008
    Same as above. How do you fix the door? Will not close completely because the spring seems to be sprung. Can't use the oven.
  • Anonymous Feb 08, 2009
    The doors are so heavy the hinges are underr a lot of strain. For the price, Viking should design hinges that could never, ever go bad.
  • Anonymous Mar 13, 2014
    removing viking oven door
  • 42 Answers
Sounds like the door hinges need replaced. order a part #PC020009 qty 2
Posted on Dec 21, 2008
Part numbers for door gaskets Viking double oven ved0530ss
Go to searspartsdirect.com with your model number. You'll find parts lists and diagrams there
Dec 01, 2017 | Viking Ovens
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
Fan stays on long after oven is shut off in brand new viking daul fuel range. It's been on now for 45 minutes. All controls are on OFF.
loads of ovens do this. It's a pain, especially if you eat in the kitchen. If you switch the appliance off and on at the wall it usually stops it. Why the fan stays on, god knows. pointless.
Jan 12, 2011 | Viking VDSC365-6B Dual Fuel (Electric and...
I have a Viking VGSC366 6B all gas range. The oven keeps shutting off when I'm baking somethimes for a long time. Sometimes i can turn it off and back on again but sometimes it won't come right back on....
When the oven igniter(s) get too old, they don't pass enough current to the gas valve to either open it or keep it open. If that's the case, they need replacement. They may still glow but they're no longer operating properly
Aug 02, 2010 | Viking VGSC366-6B Gas Kitchen Range
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
I have a viking VGIC365-6bss I pre-heated oven to 500 degrees and now the oven door will not open.
One of the door hinges was loose. You have to lift the door by the handle to open it.
Nov 26, 2009 | Viking VGIC365-6B Gas Kitchen Range
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Viking 36
The door can be removed from the hinge assembly by lifting upwards and outwards while the door is only slightly open - no hardware needs to be removed to get the door off. My door VGIC366 hinges did the same thing a few years ago, and simply cleaning them fixed the problem entirely.
Dec 02, 2007 | Viking VGSC366-6B Gas Kitchen Range
Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Nov 24, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
1,825 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
