Question about Samsung (sw-248f) CD-RW Burner
Samsung cd burner and roxio software
I have an HP pc with XP and a smasung cd burner. I installed my roxio ez cd burner 5 on my pc. Everthing is fine till I press record then a message come up saying I need to check web update. cant find anything there.
3 Suggested Answers
  • 16 Answers
SOURCE: I need the driver for samsung sw-252 CD-RW Burner
May be there are some cable fault. Just check that the cable CD-RW to Motherboard and the power cable from SMPS attached in CD-RW is ok. Then try. If it works then fine. If not, then just format C drive(Or where u have installed the OS). Coz I've already gone through a problem like this. In that case the cables ware ok. Then I just format the C drive and install a fresh copy of XP. And works fine till now.Let me know the result.
Posted on Dec 11, 2008
SOURCE: Samsung SH-S202N CD DVD burner
I have the same Samsung Multi DVD Recorder as it calls itself and it works OK with XP for me. You probably need to install the Nero software that came with it as it normally contain the hardware drivers that are needed. Sorry if I'm too late with this reply but I only just came across your post.
Posted on Apr 06, 2009
  • 27725 Answers
SOURCE: windows xp will not recognize a newly installed
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 26, 2011
0 characters
1 Points
I'm trying to burn a music cd and the comment pops up. " disc burner or software not found". My internal cd dvd burner is internal and it's not even showing that I have an E: drive now....
Firstly there is a qwerk with windows 7 in that the dvd drive is not always there in computer. You will sometimes see it there and at other not. Dont worry. However what cd burning software do you have? the most popular are Nero and Roxio. If you do have some on your pc then reinstall it and hopefully all will be well.
Jun 26, 2011 | HP CD & DVD Burners
Installed Samsung SH-182 SH-S182 DVD Burner But my computer windows XP is not reconizing the newly installed unit
Which OS Service Pak is XP using? Have you tried to update the drivers? ' System ' Hardware ' Device Mgr
Can you test the burner on a 2nd PC? My older PC's dont see the DVD-RW but the burning software does.
Feb 21, 2011 | Samsung SH-S182 DVD±RW Dual Layer Burner
I removed my old cd rom that came with the computer and put the new one in.when i put the cd in that came with the new cd rom it said installation was unsuccessful.i bought the hp dvd1270i
Usually the software that comes with a new dvd/cd burner is just burning software (nero or roxio).
Your drive is just plug and play and windows has all the drivers that is needed.
I would uninstall the software you installed and try it with free software like IMGburn or CDburnerXP
Nov 07, 2010 | HP DVD±RW Burner
Can't load my burner
The CD Burner drive is compatible with your Windows XP the software version is where the problem is. You need to get an updated version of the burner program, something like Nero burning ROM or Roxie EZ CD creator.
Corporate Computer
May 15, 2010 | Acer (99.B0112.102) CD-RW Burner
Cd burner saysinsert a blank disc, even after I do, can't burn cd
The disc must not be compatible. Check the manual for compatible disc list.
Nov 23, 2009 | Pacific Digital X-treme 52 (TREME52)...
Hp 1040i xp problem
I'm not sure if this will help you but read this link I'm sending. I went round and round with 3 different highend motherboards and processors and kept getting error after error, everything I read in forums, the tech guys, everybody seemed to go to my memory as the problem but low and behold I wasn't believing them and my research paid off. Maybe the intel/hp problems I was having are related to yours. The acceleration software maybe. I dont know but you might want to give it go. I was a little shocked that my brand new dvd writer intel conflict would cause the blue screen of death. sorry so long but if this helps anyone I'll be glad. Thanks, great days to all, Dave
Jul 14, 2008 | HP LightScribe dvd640i (DVD640I)...
CD/DVD Combo Drive Just Not Burning DVD
I had problems with tsstcorp in my drive. The software you are using won't work. You need to try sonic or roxio. I had the same problem. Do you have a dell? if so download the updates from the support website. Try a different software because a reinstall of xp should get rid of bugs in system. It sounds like a software issue though.
Apr 14, 2008 | CD & DVD Burners
Window media player
This would be Known As A conflict, ( With I.Player )
Why Don,t you try installing Another CD Burning Program. Neros Not The Only One.
Try Roxio Easy CD/DVD Creator, Or Look On The Internet For Burner Software For Download.
Posted @ 20.57PM ( G.M.T ) :)
Mike @ Compurepair.
Mar 02, 2008 | Samsung (sw-248f) CD-RW Burner
Dvd rom detecting problem
You need to find what DVD reading and CD and also DVD burning software you had, then download versions of the programs compatible with Win 98--then they should work fine. Your CD/DVD drives will be ignored until you get the correct burning software installed. Go t Samsung, which hopefully will have the appropriate downloads for Win98. If Samsung no longer has what you need, find any software for Win98 such as Roxio, or hopefully freeware, and you should be back in business.
Feb 12, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Hp 1040i xp problem
Hi there try downloading the drivers from HP site for your product for XP home edition.
Thanks J
Feb 07, 2008 | HP LightScribe dvd640i (DVD640I)...
Samsung (sw-248f) CD-RW Burner Logo
54 people viewed this question
Top Samsung CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Are you a Samsung CD and DVD Burner Expert? Answer questions, earn points and help others
