Question about Brother MFC-3240C All-In-One InkJet Printer
Wont recognise cartridges after i installed them?
Brother says open and reinstall......over and over again, what do i need to do?
No matter what i do dont copy the paper come out blank
Posted on Mar 07, 2008
    Scholar:
  • 43 Answers
Did you change cartridges? Are they Genuine Brother? 3rd-party inks are not cut up to what they used to be... a real compatible ink. You may arrange cartridge replacement from your vendor. I'm going out on a limb here but for a new cartridge intall, have you taken off the seal completely? Check the ink cartridge slots for foreign objects and make sure they are firmly seated.
Posted on Jan 17, 2008
Brother mfc-j220 printer always say cover is open how do i fix it?
make sure the cover do not have any paper / items blocking the cover, place the printer on a "flat" surface, make sure your USB cable is not longer then 1.5Meters, try reinstall driver and try again, good luck :)
Aug 07, 2013 | Brother MFC-J220 All-in-One Color Inkjet...
I had a paper jam a while back. Now I get about three sheets to come out and then I get an "unable to print 36" error. It clears when I unplug the printer, but same thing again after 2 or 3...
i had the same problem !! drove me nuts!! i first checked there was no paper stuck by hand feeding a sheet through the printer, u need to open it at the back lift the scanner lid and roll the white plastic cog when feeding the paper through. make sure the machine is switched off and unplugged. then uninstall the brother printer programme on your computer, restart and reinstall the programme. ta ta it now works again!! good luck
Feb 17, 2011 | Brother MFC 6490CW InkJet Printer
I removed the paper jam from the drum of my Brother 7050 printer but it did not reset. What can I do now?
Printer rules for reset and troubleshooting hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving
Jan 31, 2011 | Brother HL 7050 Laser Printer
How do i fix an engine interface error on my brother 1230 printer
Printer rules for reset and troubleshooting hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
Jan 30, 2011 | Brother HL 1430 Laser Printer
Poor print quality brother mfc5860cn
Possible fault or weakness of the printing heads, possible poor ink cartridges or poor settings.
Open printer properties and set the contrast and brightness levels to desired conditions and make a est. Readjust and try once again .If there is no result try to reinstall the drivers and test. If not the head and ink can be suspects.
Jan 10, 2011 | Brother Office Equipment & Supplies
Error 36
Hello there! I did the following: Unistall all drivers and reinstall them again. This will solve your problem. I got the same every 3 or 5 times and had to open covers as "jam paper", then the printer worked with similar problem (error 36). Now I unistalled the MFC suite and reinstalled the drivers and the printer works just fine. Regards
Nov 22, 2010 | Brother MFC 6490CW InkJet Printer
Brother MFC 8460N error cc3-003-00031c0e
1.Uninstall all of MFL Pro
2.Delete HKEY_CURRENT_USER\Software\Brother\ControlCenter
3.Delete HKEY_LOCAL_MACHINE\SOFTWARE\brother\ControlCenter 4.Reinstall MFL Pro
Aug 02, 2009 | Office Equipment & Supplies
Paper jam
The issue is with the Paper Feeder roller , either its worn out and needs an replacement.
Apr 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
After reinstalling it wont scan or send faxes, the error comming up is error initializing in control center2. lack of registrer information. Install once again MFL-pro suite please help thanks C.
ununstall the brother software that came with the machine, then reinstall the cd brother mfpro sofwar, if you are still having a problem, let me know. brother tech
Dec 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
Mfc 215c printer ink problem
yes. unplug machine from power outlet. take all carts out. wait 5 min. leave scanner top open when powering up again. machine demands carts. reinstall carts and ANSWER display.
DO run a firmware update afterwards (see brother homepage of your country).
Mar 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
69 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
