Question about Microsoft Windows XP Home Edition
Dell Latitude d600 Laptop comp_ Error code 0f00: 136c
Msg: IDE device failed blank media or no media is present in optical device. Test requires media with digital data (resource CD, installation Cd).
I retried it after I inserted installation CD in to CD drive but my computer still does not work. It gives UNMOUNTABLE_BOOT_VOLUME
Tecnical problem
STOP: 0X000000ED(0X827AAC30, 0X00000006, 0X00000000, 0X00000000)
What do I need to do to fix this problem. Please help
Thanks
Bayer
  • ohiotom May 11, 2010
    It could be hardware or software. I would probably try a repair install first. If it works you will not lose any of your files. Take a look at this website:
    http://www.michaelstevenstech.com/XPrepa...
    There are good step-by-step directions on how to perform this task. If this fails I would next download Seatools from Seagate. It will work even if you don't have a Seagate hard drive. If need to try this step and can't find them let me know. You'll need to create a bootable CD once you've downloaded them. Again, ask if you need help.
    This can be a tough problem to solve. It may not be solveable so I'm whimping out and putting this under the "Request for additional Information" so you cannot rate me. I don't get paid for this...it's just a hobby. Lots of people who visit this website are wary of replying to problems like yours because it may not be fixable and then we get a bad rating. If I've actually helped at all and you want to rate me, let me know and I'll post something under a solution....in any event good luck.
  • 2,427 Answers
I think its your harddrive mate,, it might not be connected propperly or its dead, look at the connection and ensure its connected, if it is connected correctly, you may need to change it..
Posted on Jan 12, 2008
  • Rishi Roshan Ali Jan 12, 2008
    TRY FORMATTING IT FIRST,,, IF IT STILL CANT READ TO FORMAT OR AFTER,,,, THEN you will need to change it,,,
Error code 00F0:136C IDE FAILED BLANK MEDIA OR NO MEDIA IS PRESENT IN OPTICAL DRIVE. IS THE HDD FRIED OR WHAT?
You probably ran the 32-bit diagnostics in this Dell computer.
The error code 00F0:136C, actually is talking about the "OPTICAL DRIVE,"which is your CD/DVD ROM; not the hard drive.
That will fail since, I am assuming you didn't put anything inside the CD-ROM.
The diagnostics tests everything and in this case, it tested the CD-ROM and failed since there is no CD inside the CD/DVD-ROM.
Hope this helps.
Thanks,
Oliver
Jul 28, 2011 | Dell Inspiron 6000 Notebook
I have a DELL imension 3000 that is showing a blank screen when booted up. I have ran an express diagnostic check and it has given me the following error: Error Code:0f00:136C IDE Device Failed: Blank...
1.If there's a cd or dvd in the cd/dvd drive, remove it and try booting again.
2.press DEL at the start up screen to go into BIOS. go into BIOS and change the boot sequence options, set it to boot from the hard drive.
May 22, 2011 | Dell Dimension 3000 PC Desktop
Error code; 00f00:136c IDE device failed; Blank or no media is present in optical drive. Front panel audio and flex bay cable: not installed Onboard or USB floppy drive (not present) Onboard IDE hard...
the diagnostic was looking for media in the CD drive during the test. If the drive works in Windows and reads media or you can boot to the CD drive, then there is nothing wrong.
Jan 07, 2011 | Dell Dimension E310 PC Desktop
Msg ide device fails on short status test .Error code1000-0142. dell error code 0f00:136c.shuts down before boot is complete and restarts attempt every 30 sec. E-mail imdoboy@hotmail.com Thanks Tim
The fatal error 0142 means that the HDD of your computer has gone bad and needs to be replaced... So please go ahead and replace the Hard drive
Nov 22, 2010 | Dell Latitude 100L Notebook
I have a Dell Inspriron B130 laptop computer. I
Dear,
This is a clear hard drive issue. Try reinstalling Operating System, If it fails again, probably you have to replace the hard drive
Oct 15, 2009 | Dell Inspiron B130 Notebook
Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
Sep 07, 2009 | Dell Dimension 3100 PC Desktop
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
949 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
