Question about KitchenAid KGRT607 Gas Kitchen Range
Kitchen Aid Oven and Carbon Monoxide Leak
About a month ago our CO detector started intermittently going off whenever we used our oven (KitchenAid model KGRT607HWH4).  About 15 minutes after the oven being on, it would go off.  We moved the sensor, still went off.  So, trying to go through home warrenty, we were referred to the gas company who came and tested the oven.  I went over the acceptable level of 200 and was still rising.  Has anyone else had this problem and is there a fix to it.  We are having problems finding a qualified repair person to deal with this.
  • Impuzzled Feb 07, 2008
    Interesting enough, we are also having the same problem with the exact same model. Our carbon monoxide detector went off as well, even before the oven was fully heated up. The gas company stated that the carbon monoxide that was being produced was well over the standard amount that should be in any home and they can’t understand the problem b/c the pilot light was burning normal and even the flame in the oven and on the burners were burning normal (blue flame = normal). He suggested we would have to contact a gas fitter to come in and take a look at it and/or call the maker (KitchenAid) and have them look at it. However, all the gas fitters in my area state (over the phone even before they look at the problem) that they cannot help me b/c they don't deal with appliances and I would have to call an appliance service guy. When I contacted KitchenAid they got me in contact with my local “KitchenAid” appliance guy to set up a service call…however, they too said over the phone that they likely will not be able to help me and there’s no point in coming out that I would need a gas fitter??? I called another appliance fixer in my area and he said that even if he thought he could fix the problem (which he didn’t think he could since it’s burning normal) that he doesn't even have the tool/s to test and see if he fixed the problem and/or if it's still leaking carbon monoxide, he’s never had this situation before.
    My home is not all that new (10 years old) and is not as air tight as what a newer home would be. My range is a 2004 model and this situation just started to happen 3 months ago (seems odd that it would start after approx. 4 years of use vs. when it was a new appliance and when my house was likely more air tight b/c it was only 6 years old then). I understand that possibly, perhaps in a in a newer home that would be more air tight, that happens to have a gas range that this could happen… however, why then, is this information not more “well known” by KitchenAid and the gas companies? I would hope that if this was a normal situation regarding air tight homes and gas ranges then they would offer this information as being “normal”. Yet, in my current situation, all involved have been inexperienced with the situation with no fix or solution just suggestions of possibilities of what could be the problem without even physically looking at the issue… the gas range.
    Are there at all any gas fitters out there that can take apart a gas range stove, or an appliance guy who has their gas license? Since there are many gas ranges out there and they are not a new thing, should there not be a person who is licensed to repair them if there is a potential problem with the appliance leaking gas?
  • Devereaux Macy Jan 14, 2009
    I purchased a home where the Sellers removed their oven and took it to their new own and bought the same oven as yours (mine is black and stainless steel, but same model #) and installed in the house. They also installed smoke detectors but failed to include co. One month after moving into this house (I cooked 2-4 hours every day) I went to the hospital by ambulance, very sick. They sent me home for another 2 months of poisoning. I finally called the gas company out and they determined the oven was defective with releasing 100% co poisoning, and red tagged it. I had been exposed to co poisoning for 3 months, 2-4 hours a day and now I have about 24 medical side effects from the poisoning, which by the way are permanent. Even if you get away from the co the damage has been done to your brain and organs, which is what all the research I have done states. I am out of pocket more than $15,000 and the insurance company paid over $20,000. It is obvious to me that there is a manufacturing defect with this oven and they are liable for damages. Have you hired an attorney or seen a doctor? Is there anything you could add to help me? I appreciate your response. Devereaux Macy
Lift up each of the heavy round metal caps over the stovetop burners then reseat them. We had the same problem with the CO2 sensor showing elevated levels.  We had just cleaned the cook top and one of the caps was not flush over its burner.  Another way to check this is to turn on each burner and see if you have a good flame all around the burner. If not, the top cap is probably askew allowing gas to escape without being burned.
Posted on Aug 12, 2008
  • 447 Answers
If you have Propane than any range will have to be properly converted to propane they are made for natural gas. Other than that gas ovens do emit quite a large amount of CO and new homes are built very air tight and any good CO detector may sense this. If you have a vent hood or hood/mwave combo and its vent is actually ran to the exterior it should aid in venting that CO. This is why the new dual fuel (gas cooktop, elec oven) are so popular. Hope this helps...
Posted on Jan 12, 2008
What does it mean when my nighthawk carbon dioxide detector reads 14. It's right above my gas oven which I have on the clean cycle
I don't know what 14 means other than the display claims to show the detected CO level. You will need to read the alarm instructions or visit the Kidde website for further information, it will not be a carbon dioxide detector (CO2) incidentally, but a carbon monoxide detector (CO).
Siting the detector high and directly above your gas oven is not suitable. It could be placed on a table in a sitting area or fitted on a wall or even the ceiling, but again I suggest you defer to the the manufacturer's guidance.
Nov 15, 2017 | The Home Security
When i use my oven ,my eyes and nose burns . why ?
I'm assuming you have a gas oven.
You may have a sensitivity to combustion by products like CO2 (carbon dioxide) or CO (Carbon Monoxide) that are produced when the oven operates or there could be a malfunction with the oven. You didn't specify a make or model, but it's important to keep the oven clean as well.
In either case, crack a nearby window when using the oven if you have one and see if that helps. Some newer homes are so tight that the oven may not have enough fresh air and the by product gasses are building up.
If the condition persists, you may want to call a repair service to check the appliance. Also, all homes should be equipped with combination smoke and carbon monoxide detectors. The CO detector will alarm if the gas concentration starts to build up, signaling a potentially dangerous situation.
Sep 09, 2015 | Magic Chef Kitchen Ranges
4 beeps with pauses for 2 year old carbon monoxide detector
I'm pretty sure that indicates an alarm. The pattern is referred to as "temporal 4" which is the alarm pattern for CO. Either your device is in a bad place or there is an intermittent CO leak which is exceeding the ppm (parts per million) threshold for a given time period. The instructions for the device will tell you what that number is. If you have more than one of these, I would try swapping them to determine if the problen is with the device or the location. Good luck!
Apr 24, 2015 | Kidde Kiddie - Nighthawk Kn-cob-lcb-a Fire...
White spots oven
This could be coming from the oven linings in the oven its food partials Try giving the linings a good clean .
Jan 18, 2018 | Ovens
Whirlpool sf362lxt oven sets off carbon monoxide detector randomly yet all flames are blue
This is caused by incomplete combustion of the fuel, DO NOT operate this oven until a qualified repair person look s at this problem. CO gas is a killer and nothing to fool with.
Feb 02, 2012 | Whirlpool SF362LXTB Range
Good Morning, My nighthawk CO detector went off with a loud continuous alarm this morning while all were sleeping. I reset it and it is not alarming now. I pushed the peak button and it reads 19. The...
When a carbon monoxide detector sends an alarm, there is cause for concern. You mentioned that the other CO detector did not go off, but maybe it is too far away to monitor the carbon monoxide levels that was in this area.
The instructions in your manual would direct you to evacuate the house immediately and ventilate. Your next step is to get a professional to inspect what may have caused the carbon monoxide leak.
A reading of 19 indicates that there is carbon monoxide in that area of your house, unless your CO detector is not working properly. Your local fire department will give you the best advice for what action to take when a carbon monoxide detector sends an alarm.
Be safe, don't assume a carbon monoxide alarm is cause by a defective CO detector, have it inspected.
Jul 30, 2010 | Kidde Nighthawk Combo Gas/co Detector
My carbon monoxide detector keeps beeping in spite of replacing thebattery and gives an error code of E09. Also it keeps flashing an err on the led redout. I placed it outside and it is still doing it...
Hopefully you have found a solution for your Carbon Monoxide Detector issue of October 4, 2009. The best solution for a questionable CO dectector is a replacement.
A Carbon Monoxide Detector is the only thing that will read, detect and sound an alert when reads dangerous levels of CO levels in your house. A defective carbon monoxide detector will give you and your family a false sense of security and will give you no protection.
Whenever in doubt, always err on the safe side and replace Carbon Monoxide Dectectors, your life depends on it.
View my website for related information and compare brands and models of Carbon Monoxide Detectors available for sale online.
Oct 04, 2009 | Kidde Nighthawk Combo Gas/co Detector
The carbon monoxide detector beeps when I run the microwave.
uplug the micro wave for the same amout of time the dector go off and see what happen if it goes off check the battery and replace them and do the same as above test to see if dector is not working properly
Jul 01, 2009 | Panasonic NN-T990SA Microwave Oven
When i increase the temperature control the oven soots excessive
Check your oven for flame color; what you are describing could be deadly. It is possible that you have an air vent clogged or blocked causing the flame to burn yellow indicating incomplete combustion and possible source of carbon monoxide. This is very dangerous and I would strongly recommend you purchase a carbon monoxide detector. We have one on the main floor and one in our basement.
A defective gas floor furnace in a home in a neighboring town 2 days ago put three children and two adults to sleep during the day and a 64 year-old man died of the fumes. The others are recovering but are all hospitalized. The family moved to Clay, WV from New Mexico only a week ago.
Dec 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Carbon mono detector alarming, flames high
the oven comes from the factory set to be used on natual gas. its souds like your on LP gas. if so there should be a conversion kit with the range or instruction in the owners manual on what to do to convert it. all ranges ar diverent when it comes to converting. you need to follow the instruction in your manual
Nov 22, 2007 | Frigidaire FGF316 Gas Kitchen Range
KitchenAid KGRT607 Gas Kitchen Range Logo
1,459 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
