Question about HP Photosmart 2610 All-In-One InkJet Printer
FAX Machine problem
The FAX machine is connected and connecting to other FAX machines, but it is unable to transmit DATA.   Is there anything I can do or is the machine done???
  • lisa_mikel Jan 13, 2008
    It didn't work - I think it's done!
  • 4,102 Answers
Hi if you are sure that all leads are connected properly and not damged if it is not a problem with leads then their isnt much you can do as getting this repaired will cost as much as a replacement after alot of use these make of machine tend to stop reading the info that you put into it ie fax.
Is the rest of printer working fine or is the whole lot not working usually you will get the printer part working and the fax part not. its to do with the scanning heads wearing out of alot of use.
It dont work out worth geting repaired as the cost of replacing the parts needed are nearly as much as buying new printer and also parts are hard to come buy for this make.
But before you give up on it remove all leads and refit give it another try try holding down the on off button for 5 seconds or more this should reset the unit then also try again failing this their isnt much you can do yourself as getting parts is difficult and not cheap.
Let me know how you get on and if you need anymore help sorry i couldnt give you good news but make sure you check all leads
Posted on Jan 12, 2008
    President:
  • 1,944 Answers
Reinitialize and check the fax machine
  1. Disconnect the power cord from the back of the fax machine and from the wall outlet. The fax machine will reinitialize when it is plugged back in. You must disconnect the power cord, turning the fax off using the power button will not reinitialize the fax. Leave the power cord disconnected for now.
  2. Verify that the phone cable is fully inserted into the fax machine. If your model has a removable line interface unit (LIU) that the phone line plugs into, verify that it is securely snapped in place. If the fax is an HP Officejet R80 series model, also verify that the cable that runs from the automatic document feeder assembly to the back of the all-in-one base is connected.
  3. Reconnect the power cord to the unit and then plug it in to the wall outlet. After the fax reinitializes and is ready, try to send and receive faxes again. If the problem still exists, continue to Step two: Check the connections.
  • 6 more comments
  • Damen Wong
    Damen Wong Jan 12, 2008
    Check the cable connections to the fax following the directions below.
    NOTE:
    The HP Fax 1050 does not have a 2-ext or auxiliary port for use with other phone appliances.
    1. Examine how the telephone cable is connected to the fax. The fax must be connected directly to the wall phone jack and the cable should be plugged into a jack on the fax that is labeled Line, 1 - Line, To Wall Jack, or has an image of a wall jack.
      Any other devices that must be plugged into the same phone jack can be connected to the auxiliary ports on the fax as is shown below.
      If you have changed any cable connections, try sending and receiving faxes to determine if you still have a problem.
      Figure 1: Connecting multiple devices to a product with three ports
      Figure 2: Connecting multiple devices to a product with two ports
    2. Examine the cable from the wall jack to the fax. You must use a cable that has only two copper leads or wires as is shown in Call out 1 below (similar to what shipped with the fax). Replace any four-conductor cables with a two-conductor cable. If you have the cable that shipped with the fax and it is long enough, use that cable. You may also want to try changing the cable.
      Figure 3: Two-conductor and four-conductor phone cables
      1 - Two-conductor phone cable
      2 - Four-conductor phone cable
    3. If you have other devices (caller ID boxes, answering machine, and etc.) connected to the phone line, disconnect all of these devices, even if they are not connected to the same phone jack or are in another room and then try to send and receive a fax.
      • If you are able to send and receive faxes after disconnecting the other equipment, add the devices back one at a time until you discover the device that was causing the problem.
      • If faxing still isn't working, continue troubleshooting with Step two: Check the phone line. Leave the other phone line devices disconnected for now.
  • Damen Wong
    NOTE:
  • Damen Wong
    The following things are required to check the phone line:
    • The phone number for another fax machine that can be used to verify whether the HP fax is sending and receiving correctly. This fax can be in the same building, on another phone line, or at another location with someone who can assist.
      NOTE:
      It is also very helpful to call the person or company you are dialing and speak to them. They can tell you how their fax is behaving when called by your fax. This can be valuable information when trying to determine the problem.
    • An ordinary single-line phone This phone will be used for testing the phone line and testing different faxing options.
    Begin troubleshooting the phone line by following these steps:
    1. Disconnect the phone cable from the fax machine and plug the cable into a standard single-line telephone.
    2. Pick up the handset and listen for a dial tone.
      If no dial tone is heard, replace the telephone cable between the wall jack and the telephone with another two-conductor cable. If a dial tone cannot be heard after changing the cable, contact your telephone company for assistance.
    3. Dial the number of a fax you have been trying to send a fax to:
      • If the destination fax answers the line, continue to the next step.
      • If the call fails to go through, try a different number. If the second call is also not answered, replace the phone cable and try again. If it still doesn't ring through after replacing the cable, contact your phone company for assistance.
    4. Hang the phone up and either call your phone line number from a phone on a different line (like a cell phone) or have someone call your number. If the phone rings and you can answer it, continue to the next step. If the phone doesn't ring when called, replace the phone cable and try again. If it still doesn't ring after replacing the cable, contact your phone company for assistance.
    5. Disconnect the phone cable from the telephone and reconnect it to the fax. Before making any calls, change the fax settings to those listed in the table below by pressing the Setup , Menu , or Fax Menu button (depending on the model) repeatedly to access the Basic Fax Setup menu or the Advanced Fax Setup Menu.
      As an alternative you may also reset the fax machine to the factory default settings by selecting that option in the Maintenance, Status and Maintenance, or Tools menu or some all-in-one models allow you to use the software to change the fax settings.
  • Damen Wong
    1. The following sequence of events will occur if the fax is working correctly:
    2. When the fax machine starts to dial, you hear a dial tone briefly followed by the sound of the fax dialing. "Dialing" will appear in the front panel display.
    3. When the fax you are calling answers the line, the fax machines will exchange tones and "Connecting" appears in the display. During the connecting phase, the two fax machines will compare capabilities, exchange information about how the fax is to be sent, and try to establish a reliable transmission speed.
    4. After a connection is established, the pages of the fax are sent. "Sending page 1" or similar message will appear in the display.
    5. Dial the same fax number you called in Step 3 using the front panel. Watch the front panel display and listen to the fax.
    1. If the fax is transmitted successfully, continue to the next step.
    • If you do not hear a dial tone and/or the other fax does not answer the line, try calling another fax machine (the first may be busy) to verify that the result will be the same. If the second attempt also fails, proceed to Step four: Final steps to try below.
    • If you hear the other fax machine answer the line and starts "beeping", but the display on your fax does not switch from dialing to connecting, the fax machine is not detecting the tones from the other fax machine, proceed to Step four: Final steps to try below.
    1. Have the owner of the other fax machine send you a fax. Watch the front panel display and listen as the fax tries to connect.
    1. If the fax is received, the problem is corrected and the fax machine is fully functional.
    • If your fax does not ring and/or does not answer the line when the other fax is sent, have them try again to verify that there is a problem. If the second attempt also fails, proceed to Step four: Final steps to try below.
    • If the fax rings briefly and then stops, something else is answering the line (another fax, credit card machine, PC faxing or communications software, or voice mail). You must determine what is answering the line.
    • If your fax answers the line, the message on the front panel display should switch from "Answering" to "Connecting". If this does not occur, the fax is not detecting that the other fax machine. Proceed to Step four: Final steps to try below.
  • Damen Wong
    Did you go through everything above? The instructions are from HP's support site.
  • Damen Wong
    Can your machine receive faxes?
  • Damen Wong
    Damen Wong Jan 13, 2008
    Can your machine scan?
  • Damen Wong
    Try, if possible, another phone cable and phone jack.
    Fax to 1-815-346-2473 on my SF 650 machine?
    Dear
    first check the no 1-815-346-2473 with your telephone company. In the said model there is a handset. do -lift hand set here the companys dial tone dial the required tel. no. here the Rx.tone from the other fax machine connected. If its working definitely your fax machine will transmit the data.
    If the fax machine has connected behind EPABX, it has unique no. to dial out side of the epabx. In that case contact your EPABX provider to program the fax machine.
    Thanks.
    Dec 18, 2014 | Samsung SF-650 Laser Fax Machine
    We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
    Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
    Oct 05, 2010 | Brother Office Equipment & Supplies
    I'm getting an error mesage: ECM error on my Sharp AR-M207 fax machine. How can I fix it?
    ECM (Error Correction Mode) is a feature common in most fax machines today. It helps to minimize errors while transmitting faxes over noisy phone lines.
    1) Be sure you have the latest version of the drivers installed
    2) Turn the fax off, then unplug for 10 minutes, turn on and try again. This should clear up anything in the printer/fax memory
    3) Check if your phone line is unsually noisy when you tried to send the fax(es) that gave you the error message. If this is the case, a sucessful fax transmission will be almost impossible. You may have a faulty phone line or an improper installation. Either of these two should be fixed by your phone company. Also, most phoen companies can test your phone line (for fre) remotely to check for abnormally high noise levels.
    Please, report back if you need further assistance.
    My ID: alexocuello_
    Mar 31, 2010 | Office Equipment & Supplies
    Fax Error 386, HP 6110xi Fax failed Is there a solution?
    See http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
    Too much noise on the phone line: e.g. bad connection, unshielded phone cable next to a electrical machine (motor!), temporary problems in phone service providers network.
    Fax is essential data transmission by beeping noises. If crackling on the line or other disturbances degrade signal quality too much, the data cannot transmitted properly anymore.
    Feb 09, 2010 | HP OfficeJet 6110 All-In-One InkJet...
    How to change fax speed from14.4 to 9600
    The machine does this automatically on connection. It negotiates a reliable connection speed with the recipient machine and then transmits data. If in encounters an error repeatedly it will negotiate the speed down even further until the data can be sent successfully. However the following menu setup option may help
    Main MenuFaxSetup SendOverseas ModeOn will change the speed down to 9600 max and negotiate downwards if required.
    Oct 30, 2009 | Brother Multi-Function Center MFC-240C...
    Peoplel are sending me very imp. faxes and idk how to recive it..
    If your printer has FAX capabilities. Good way to tell is if you have a phone number pad on the front of your printer.
    You must have this connected to a phone line for it to receive a fax.
    Setup the fax application through your installation CD that came with the Printer/fax machine. Often you set the fax machine to pick up after so many rings. This allows you to leave the printer/fax machine on and gives you time to answer BEFORE the fax machine does. If uncle Bob or Aunt Susie should call to say Hi!
    Basically what is happening:
    You turn on the Printer/Fax machine it sits idle waiting for a phone call.
    Someone now sends you a fax using your phone number.
    YOUR printer/fax machine is sitting there listening for the phone to ring.
    Lets say you have your printer/fax machine setup to answer after 5 rings.
    After 5 rings, your Printer/fax machine will pick up and listen for signal tones from the the other machine. If it gets these, it will "handshake" and send a confirmation fax tone. Then the data will be transferred and printed out on your machine or held in a fax program for you to print or save later.
    It is critical that you do not pickup the phone too early or the two fax machines trying to communicate will fail.
    If you do this, you will hear an awful squeal and a serious of tones.
    You can often hang up quickly and the two machines will transmit again the handshake signals and resume business as usual.
    Short answer:
    Two fax modems are talking to each other over your phone line to transmit data.
    and hope this is helpful.
    Oct 04, 2009 | Canon MX310 Office All-In-One Printer
    Error code 345
    The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted.
    Number of possible causes, check the phone line, try a different fax number for a start. Is there other fax machines in the office on the same line
    Sep 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    Fax machine Disconnecting
    Have the phone company test your connection to him the signal may be weak/poor connection.
    Jun 04, 2008 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
    Fax
    There are two sockets on the machine for telphone cable connection. one is for tyhe machine to be connected to exchange and other is for a phone set to mbe connected to machine. connect the line from exchange to the plug marked with "LINE". also check if your telephone company atually support fax communication. some comanies do not support sending of fax on there network. There is no software to be installed for fax. Good Luck,
    Jagpal
    Jun 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
    I am trying to connect my all in one HP J5780. I can't get the fax connected. I have DSL & I cintacted my provider and he was unable to help me. I get : Fatal error MSi.imagezoneeexpress. Can...
    Do you have the adapter for DSL? If you don't have an adapter to get a standard phone signal, the fax machine won't recognize anything. The DSL connection is fine for your DSL modem that your computer connects with, but the fax machine, even in an all in one, has to have the adapter to be able to work. Most of the time you can obtain these adapters from the company you have your DSL service through. I am curious why they did not suggest this to you.
    We have used DSL, and had to have the adapter to be able to use either a standalone fax machine or a standard modem.
    May 13, 2008 | Office Equipment & Supplies
    HP Photosmart 2610 All-In-One InkJet Printer Logo
    49 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
