Question about Ovens
Front Panel Controls
I have an older GE Oven Model # J35CKW-4 and I cannot seem to find any info on how all the programming buttons work - can you help me?
Cheers
Bill G.
I've got the quick guide that shows how to use the front panel. I can scan and upload if you wish.
Posted on Apr 30, 2008
How do I fix my GE True temp oven which shows F7 on the display?
https://www.youtube.com/watch?v=Rg7Dp4LBxtA
it seems its the connections ribbons on the control panel is wrong
will give you a clue look down the replys to the video to get more info
some very carefull cleaning is needed inside the front panel rework some connections
i use deoxit 5 and a rag
spray the deoxit to a rag then wipe the connection ribbons
then dowse the plugs with the deoxite
wait a while and re plug then carefully
should cure it
i would add a blob of grease to the sockets once its all running
to avoid further corrossion
hope this helps
Dec 11, 2014 | GE Ovens
GE oven controls lock after opening door and steam from cooked food comes out
you may find there is some insulating material missing internally as I would imagine steam affecting the front of the control panel
Nov 14, 2013 | GE JTP70 Electric Single Oven
Built-In Oven Buttons Stop Working
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
Email me for some pictures:
schmidtkeith1@yahoo.com
Aug 02, 2009 | Maytag 30" Built-In Single Electric Wall...
GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Nov 25, 2007 | GE JRS04 Electric Single Oven
Built in GE wall oven
why are you trying to remove the panel are you talkin about the control panel
Nov 13, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
97 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
