Need to replace the glycol oil (coolant) in our rear projection tv
We have a 60" Phillips Magnovox television that needs to have the fluid refilled in the blue tube. Where can you purchase the glycol oil to do it yourself
  • 4 more comments
  • tylerevan Jan 12, 2008
    Need to purchase glycol oil (coolant) to refill television tubes
    Thanks for the quick response. We would love to have instructions on how to do the procedure. Thanks
    Thanks so much. We will let you know how it goes once we are able to order the coolant. Do you have any idea how much this coolant costs?
    One more question. Do you have to refill all the colors or just the one that looks like oatmeal?
  • typhou Jul 14, 2008
    where can i order glycol oil for my projection tv tube?
  • Anonymous May 19, 2009
    need to replace the glycol in my magnavox
  • sanders20558 May 11, 2010
    How many bottles do i need if i want to replace the coolant in all 3 crt's on my Philips 50p8341a???and how can i focus the crt's, adjust the convergence and get the best image of my TV set??? this will be my first time. and i want to get the job well done THANKS...
  • 8,617 Answers
You can get The Picture Tube Coolant at the link here Matt electronis. they offer quick shipping, And if you need instructions on how to do the proceedure , please let me know
http://www.matelectronics.com/cgi-bin/ss000001.pl?SS=coolant&PR=-1&TB=A&SHOP=&ACTION.x=16&ACTION.y=9
Posted on Jan 12, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jan 12, 2008
    I will have to post the instructions in two seperate post as its too long. Hope it helps.
    Changing Projection TV Coolant
    1. Tip the TV set so the expansion chambers are pointed up. The expansion chamber is a small white/clear plastic bulb-like thing that is attached to one side of each of the CRT's up near the top lens. In some TVs, the expansion chambers are already pointed up - In this case you don't have to tip the TV
    2. Cover the circuit boards below the CRT's with several paper towels to prevent accidentally spilling any coolant onto the boards.The coolant is corrosive and will destroy the circuit boards. Don't skimp on the paper towels here - they are cheap!!!
    3. Remove the four screws that hold on the focusing lens assembly and remove the focusing lens assembly.
    4. Note the position of the expansion chamber then remove the expansion chamber. It will need to be reinstalled in basically the same position so remember the position or take a picture if you need to. There is a small o-ring on the neck of the expansion chamber where it threads onto the CRT housing - Don't loose it!
    5. Use the baster and tube to suck the fluid out from the hole where the expansion chamber was removed. This hole is fairly small...maybe 5/16" or so.
    6. Once most of the fluid is out, remove the four screws that hold on the lens cover plate.
    7. Remove the lens cover plate, the lens & the large o-ring. (be gentle with the o-rings!!!)
    8. Clean the CRT chamber & lens with denatured alcohol. Use 100% cotton balls so you don't scratch anything.
  • Sonny Berry
    And the second part is;
    9. Clean the CRT chamber and lens with distilled water. Again, use 100% cotton balls so you don't scratch anything. This will rinse out the alcohol residue. You need to use distilled water for this so there is no mineral residue.
    10. Gently clean the large o-ring with distilled water (don't use the alcohol because it might eat the o-ring) Dry off the o-ring and lightly coat it with 100% pure silicone (not siliconized acrylic caulking or acrylic latex caulking - ONLY USE 100% SILICONE).Use your fingers to rub a thin layer of silicone all over the surface of the o-ring. Then place the o-ring in the groove in the CRThousing.
    11. Place the lens in its position on the o-ring.
    12. Place the lens cover plate over the lens and install the four screws.
    13. Clean your baster and tubing with denatured alcohol then rinse with distilled water.
    14. Use the baster and tube to suck clean fluid from the bottle and install it into the CRT through the expansion chamber hole. Goreally slow when it is almost full to minimize overflow. Wipe up any overflow immediately. There will be a small air pocket inthe CRT when you are done - you will not be able to fill the chamber 100% - This is O.K. Just be sure to fill it as far as possible so the fluid is just up to the edge of the expansion chamber hole.
    15. Install the expansion chamber. Be sure to install it in the same position as it was before you removed it. Also be sure that the small o-ring is on the neck of the chamber before you thread it on. The chamber is just plastic so don't over-tighten it or you might damage it. Screw it on as tight as you can go by hand and then give it about 1/8 of a turn with pliers. (you might have to use needle-nose pliers to get a good grip on it.)
    16. Place the focusing lens assembly into position and install the four screws.
    17. Turn on the TV and check for leaks over the next 20 minutes. Remember, you have not yet removed all the paper towels from inside the TV. Remove these once you know there are no leaks.
  • Sonny Berry
    Usually Blue and green are the ones that gel up. Red seems to last alot longer. I would do just the effected ones. Hope this helps.
You'll probably want to short the anode before messing around those crts...32.2kv unless of course you don't mind getting electricuted.
Posted on Jul 13, 2010
    Problem Solver:
Here is a step by step on how to change the tv coolant.
I found a some help at the following web site forum
http://www.tv-forums.com/forum/TV_Equipment_C4/Projection_TV_Forum_F24/Changing_CRT_Coolant_P15302/
I ordered the coolant from mcmelectromics.com
Projection TV Coolant - Techspray - 1915-16SQ
Posted on Feb 03, 2009
What about the folks in Canada, Will they ship to me
I have a 60" magnavox i want to change coolant and clean out the gunk,
add me on msn if you wouldn't mind me msg'n you for advice.
jstacey007@hotmail.com
Posted on Oct 01, 2008
How hard is it to change the cooling fluid in phillips projection tv.
The CRT coolant change is all mechanical which involves removing the crt and disassembling the coolant chamber so it can be cleaned then reassembled and filled with coolant the phillips CRT coolant kit from www.tvrepairworld.com has the coolant and the instructions for the repair on cd
Jul 31, 2011 | Philips 60PP9352 60" Rear Projection...
My Phillips Magnavox 64 inch tv has a green tint to it. what can i do about it and how much will it cost and where can i have it done at?
Your fluid, known as Ethylene Glycol needs replaced in the picture tubes. Normally just the green and blue need done. This is what keeps the face of the tubes cool and after time just like your anti freeze in your car it breaks down and needs replaced. It turns what we call "beer brown". At Philips, we were charging $279.00 to do this. Today, places are charging anywhere from 200-300.
Nov 26, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a phillips 50pp920217 tv and the problem is that one lens or lamp its burned. AT the bottom the pictures has a wave and shadow of color red.
Sounds like some of the coolant has been lost. Refill with the same glycol based coolant as original.
see here:
http://www.google.com/url?q=http://www.mcmelectronics.com/browse/CRT%2520Coolant/3830007&ei=VktsSr2wGcKFtgfvqYWbAQ&sa=X&oi=spellmeleon_result&resnum=2&ct=result&usg=AFQjCNHIbkkEwW3p8jUKnwgc30LApH-Xww
Jul 26, 2009 | Philips 50P8341 50" Rear Projection...
Convergence bowed
Hi
the coming out is glycol oil (coolant). If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
Looks like a picture tube problem.
Try to reduce the contrast, maybe it will be better.
Look into the three tubes while the TV is running, and observe the
picture quality of the three. If the red and green are crisper and clearer, and the blue's all hazy from bacteria growing in the coolant, then the fluid needs to be replaced. The CRTs of the colors that seem hazy need to be removed from the light box to be
serviced. The coolant needs to be drained, the CRT assemblies
disassembled and totally scrubbed clean and refilled, then reinstalled and converged. If the coolant is
clear, it can be a weak CRT.
Also the convergence STK ships might need to be replaced, and the soldering checked.
Good luck
Jul 08, 2009 | Samsung PCJ612R 61" Rear Projection...
Projection T.V.
It is called Ethylene Glycol (PTV Coolant is what you ask for) . I don't believe radio shack has it, you can try, however, all Electronics Parts Suppliers will have it. If your going to do all three tubes then get 3 - 16oz bottles.
May 18, 2009 | Philips 55PL9223 55" Rear Projection...
I have a phillips 60'' and has yellowish color around the edges
hi the problem the picture tube of ur tv has got repaired. pls rate me
Jan 18, 2009 | Philips 60PP9363 60" Rear Projection...
My 60inc phillips magnovox has poor color, what do i have to do?
we just bought a 55 inch phillips magnavox and told it was working fine when we got it home and turned it on it was a red screen and was really foggy. we looked up some tv repair places and ONLY 1 told us it was the picture tube and to look down them with a flashlight for bacteria! sure enough the green and blue had it. so we found one place that would sell us the coolant fluid that you have to change the others could get it in or wanted us to bring the tv to them. we did it our selves the stuff was $17.00 a bottle or if we took it in it would be about $375.00. we have a great picture now and it wasn't as hard as all the other repair places said.
Dec 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Just want to know if I have to buy a new TV
you can get the parts at the following link. Leave them an email with your model number and what youre needing they will respond quickly to your email.
http://servicemanuals.vstore.ca/
Aug 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnovox 9P5531 C102
you need to change the coolant in the CRTs. Thats a common problem with the blue and green CRT in phillips magnavox rear projectionsIt makes the color and clarity as good as new after the coolant has been changed. If you need more info let me know, as there is a kit that has the coolant for all 3 tubes and CD with the step by step instructions with pictures available.
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color & sharpness problem
Sounds like you need Coolant fluid change, this is the fluid under the Lenses. If you have not done this before I suggest that you get some one who is qualified. Because if the coolant leaks and get to the circuit board, there goes your tv. You need new fluid in the 3 CRT's. If you look down with the back off and looking in the lense, you would see contamination in the fluid, this needs to be taken out and cleaned and replaced with new fluid. The fluid can come from places like MCM electronics corp.
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
8,462 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
