Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Windows not able to detect Hard Disk in My computer
I have formated my portable Simpledrive hard disk,now my system is not showing it in my computer.I think it has lost its system volume information.
  • josephine1 Feb 10, 2008
    I am trying to install program by use of CD. My computer does not recognize or cannot find program.
  • djhoski420 Mar 21, 2008
    My problem is similar. Windows doesn't recognize that the drive has been plugged in. When I go to Disk Management, there are four entries. The first one is blank, and under the file system column it says "FAT". The others are my C:, D:, and E: drives. So it doesn't recognize my external SimpleTech at all.
    Novelist:
  • 109 Answers
1. Rightclick on your "My computer" icon.
2. Doubleclick the Manage option.
3. A screen will appear called: "Computer Management".
4. In the tree on the left you see "Storage" and the option "Disk Management" below it.
5. Select "Disk Management", and locate your SimpleDrive.
What does it say? If it shows only "Unallocated Space" you'll need to create a new partition on it. (Right click the unallocated space, then it'll show some options). If it is allocated, try formatting it. If you don't see your drive > reconnect it.
Let me know if this helped. Please rate.
Greetings,
DarkNeogen.
Posted on Jan 25, 2008
This has been most usefull thanx alot
Posted on Oct 09, 2008
Not able to detect the Transcend USB 2.0 Portable HDD in Windows 7. Although the System Drivers are perfectly installed. and system is working fine .
Most likely issue here is the drive is not formated. i am assuming it is a new one.
right click on "my computer" select "manage" from the bar on the left select "disk management" under the "storage" tab check to make sure your hard drive is listed therein the section to the right. if it is right click on it and select format select NTFS and I would suggest check the "quick format" box (otherwise it'll take about a million years to finish) hit okay once it is done your hard drive should be ready to go! windows should now list in under my computer and it will act like normal.
Feb 28, 2011 | Transcend 500GB 2.5 INCH PORTABLE HDD...
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
How can i format my laptop
Step 2
Step 3
Step 4
Step 5
Step 6
May 06, 2010 | Computers & Internet
Transfered contents to a terabyte drive weeks ago. Not recognized
thats a file system related problem, try to download this file systems repair tool, let see if work. download data recovery wizard tool from this link. http://www.easeus.com/disk-copy/download.htm
Apr 13, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
My mac is not let me save on my simpledrive, it lets me take them off file
Check the file system the drive is using under Disk Utilities.
It has probably been formatted as NTFS since you're able to read the files but not write them.
You'll need to Erase the drive under disk utilities and give it the MS-Dos format in order to write files to the drive. If you're ONLY going to use it on a mac then choose Journaled.
Let me know if you have any other questions.
Nov 23, 2009 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Nov 13, 2009 | Computers & Internet
I have a 320 g simpledrive and it was working properly, but not its not being detected by windows vista.
Try going to control panel-Administrative tools-computer Management then disk management. If it show there set ti active /primary
Aug 01, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
General questions regarding simpletech simpledrive.
You probably have to initialize and/or format the drive.
Right click my computer and click Manage (assuming windows xp)
Go to disk management
See if you see the drive listed somewhere there. Should show approximately 950gb disk drive
If so right click that drive listed and choose either format, or create partition.
If you create the parttiion, make sure to click quick format, otherwise it will take a long time.
Hope this helps
Jul 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
Hard disk siz problem
Use Partition Magic to parition and format the hard drive.
Apr 26, 2009 | Seagate 750GB ST3750640AS SATA300 16MB...
Installed a new hard drive
Well, since the new hard disk is not formatted, and there is nothing currently on it, you will not get a dos prompt or an operating system detected. What you need to do is insert your Windows XP disk, then reboot the machine. When you see the HP screen, tap the F12 key, which will take you to a boot menu. On the boot menu, choose your CD drive, then the computer will boot from the windows disk. From there, just format your disk, and install Windows.
Apr 14, 2009 | HP Pavilion 520c PC Desktop
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
1,001 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
