Question about Compaq Presario 5000 PC Desktop
Remove And install CD-ROM
I did not give enough info on my last request.The Model # of the Compaq 5000 is 5BW120.-It is not just a simple unscrew situation I found the disassembly info on the HP websight And There seems to be 2 configurations under the 5BW120 and they show one and I have the other. It probably is a simple procedure if one can figure it out.
Thank You
Ray
  • computerray Jan 14, 2008
    Re-Writing my question and the answer I received.Thanks to all of you-
    Ray
    Can any one tell me how the CD and DVD drives are locked into the case of a Compaq Presario 5000 and how to remove them. They do not have the quick release tabs like the hard drive and no visible screws. Any assistance greatly appreciated!
    AnswerOn the front of the computer is that little cd holder pop out thing, open it. There's 2 little holes to pop off the colored plate. pull it off, you'll find the tabs to remove the drive on the front, underneath the colored plate.
  • ohiotom May 11, 2010
    What is giving you trouble? Are you having a problem physically getting the old CD-ROM out of the case or getting the case open?
    Sergeant:
  • 263 Answers
First you have to remove both sides from the computer case the screws are on the back of the computer then pull to the back each side cover and in the back of your front panel inside the computer there are some like plastic clips attached to the metal case open them and push the plastic front cover tours to the front each time you do the un clip ones the front is remove there is like an other little case that is holding the cd-rom and it has a screw remove the screw and pull it tours to the front it will slide out with no problem remove the screws from the side of cd-rom and pull it out to replace for other one just follow the directions backwards fixya rate
Posted on Jan 13, 2008
How to booting from cd rom on hp compaq 6710b and install ubuntu
Press F9 at startup. This will give you your boot menu. You will then be able to boot from your dvd-rom / upgrade bay etc. 27bd1b34-d4db-4891-9414-81770f593217.jpg
Sep 24, 2014 | HP Compaq 6710b Notebook
I have e machines EL1300G-02W desktop pc has dvd rom can i add a cdrom drive?
Your DVD-ROM drive will also play CD's. You can also easily remove it and replace it with a CD-ROM drive if you like. Simply open the case, unscrew the DVD-ROM, remove the power and data cables from the back and pull it out through the front of the case. Installing the CD-ROM just involves doing this in the reverse order. Make sure your computer is off and unplugged during this process.
Mar 05, 2011 | E-Machines eMachines Desktop PC
My TS-H653N CD Rom device does not work. What do
Buy a new one and replace it. Follow this tutorial on how to do it:
1. shut off your computer.
2. Unplug the power cord from your computer and the rest of the wires from the back of the computer.
3. find a sturdy flat surface on which to work on
4. unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
5. open your computer up by taking the side panel off, or sliding the cover off.
6. unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
7. unscrew the 4 holding screws on both sides of the cd-rom drive.
8. now, you just have to remove the cd-rom drive, carefully by sliding it either forward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
9. Do everything in reverse to install a new one.
Jul 19, 2010 | Compaq Presario 5000 PC Desktop
My note book compaq presario modelno. c700tu is not giving soun
http://welcome.hp.com/country/us/en/support_task.html
go to site and enter model number and u will find everything releted to your notebook
Jun 24, 2010 | Compaq Presario 700 Series: 1170B01...
How to Install WinXp in Vista Platform
There is very simple procedure.
  • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
  • After entering in BIOS setup change the Boot order or Boot sequence.
  • Select the booting device 1st boot from CD Rom.
  • Save the setting.
  • Insert windows XP Cd in CD Rom.
  • Now Computer start from CD Rom.
  • You follow the instruction and install the windows.
  • Compaq Notebook Drivers
Mar 20, 2010 | Compaq Presario Notebook
IT STOPS IN THE MIDDLE OF THE WASH AND RED BUTTON HILIGHTS SAYS CLEAN PUMP
Simple enough. Remove the access panel,unscrew the pump and clean out the lint. Re-install the pump screen and you should be fine.
If you have a model number and need more info let me know.
Jul 14, 2009 | Whirlpool Washing Machines
CD-ROM has not worked.
It can use a DVD-Rom just make sure that the door is the same size as your old cd-rom so it will fit into the side of your laptop and also make sure that you remove the bracket from the back of the old cd-rom and reattach it to the back of the DVD-rom you want to put in your laptop so that way you can screw it into place
Feb 01, 2009 | Compaq Presario Notebook
Help- CD Rom works sometimes
all you need to do is just have CD-ROM replace , they're cheap and easy to get , ebay selling it , not too hard to install it either .
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 5000 PC Desktop Logo
454 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
