Freezers Logo
Posted on Nov 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model ufp19n-lx2 freezer will freezebut motor run all time and hot
Anonymous
Level 3:
President:
  • Master 2,702 Answers
  • Posted on Nov 22, 2009
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
910825
Points
7895
Its very likley that the thermostat has stoped working in the on posion and the freezer is running 24/7 this wont do the compressor any good at all, change the thermostat asap,
1helpful
Idylis 5.0 cu ft chest freezer: why is the outside of my new freezer hot to the touch, while the inside is freezing?
if new and a 5 ltr
check thermostat setting
it takes some time to freeze up unit and contents
motor will run a bit longer then normal
then should kick in on and off with the thermostat
Sep 13, 2016 • Freezers
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
My refrigerator's inner fan was making weird noises. After some time I poked it and then it stopped moving. The fan is now unable to turn. What should I do?
Two things could be wrong. Motor bad or frozen up with ice.The noise could have been
from frost building up and hitting the fan.If this is the case you need to defrost. Even self
defrost models do this some times..Empty freezer and run a hair blower (dryer) to put heat
in the compartment. this could take a while to do. over night...So run blower for a while to heat up the freezer then shut it off, close door .let sit It takes time for the heat to get to the ice.
if the motor is bad you will have to take inside cover off the access the motor
Motor runs continuously
The motor is getting very hot because of running all the time and not cooling properly...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
1helpful
The freezer is hot on the outside
Make sure the evaporator coils on the back or underneath near the compressor are clean. If there is a fan near the coils make sure it's running.
3helpful
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
Frigidaire cf-5f-lx2 1989 modle
Greetings!
Since the overload was good when tested, check also the electric current if the current is in the right voltage.
If the problem still a raise, it is now the motor compressor that have problem. The motor it self cannot start or hard starting.
Thanks.
15helpful
2answers
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
