Question about Philips 170B4MG 17" LCD Monitor
Phillips 170B How do you take the monitor apart ?. Occasionally it fails to come on, no light. I think it's just a poor connection on the mains plug so I want to open it up How ?
2 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: monitor
sound like the power supply or the monitor bulb is going.
try the monitor on another PC if you can get one, if it works, then you have to find ou the manufature of the video card and get the driver.
Posted on Nov 05, 2008
Hello, I have a Philips 170 B monitor and I am having problems with it. Even after my computer is switched on- I see nothing on the screen - it's blank- but the monitor's power light is on. I've tried...
mcdevito75 here, Sounds like your moitor is burned out, I would take the monitor to a Staples, Radio shack and have it tested. Monitors are just like a light bulb and do go bad or burn out.
Aug 12, 2010 | Philips Business 170B 17" Flat Panel LCD...
Phillips 170B volume adjustment bar automatically pops up
Usually for the volume bar to just pop up something would have pressed the volume button. It is possible that the volume button has gotten a malfuntion on it and this makes it to pop-up all the time. Try getting underneath the volume button cleaned. But preferably this should be done by an expert.
Hope this solution has been helpful?
Jul 20, 2010 | Philips Business 170B 17" Flat Panel LCD...
Monitor just suddenly went off and won't come back on. What could be the problem?
Failed DC filter caps, and check the main AC fuse, the power supply should be putting out 5vdc and 18vdc the minute it is plugged into the wall outlet, check for that without turning on the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking, or have high ESR) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 13, 2010 | Acer X213WB Monitor
Green light on - no picture
I would take the PC nad the monitor to the repair shop and have them find out if the PC is out back together correctly by trying with another monitor, if it works with another monitor, then you will have to take apart the monitor to inspect the inside for bad components.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jul 08, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
Monitor turns off occasionally and you have to press the menu button to turn it back on
Check the DC filter caps in the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | AOC LM729 17" LCD Monitor
I have two Samsung 225BW 22"monitors that both quit in the same week. They just went black but will occasionally light when I squeeze the side of the monitor a bit. Its doesn't take much pressure to make...
You need to do some inspection inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 30, 2010 | Samsung SM225BW 22 inch LCD Monitor
External monitor hooked to laptop shuts off after a few minutes
Does it do the same when it is hooked up to PC as main monitor? Just to be sure before starting taking it apart. Do other monitors give the same result when it is hooked up to this laptop?
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 02, 2010 | Dell Computers & Internet
No sound from headset plugged into monitor
From the manual I found, this model does NOT support ANY audio connections.
http://www.p4c.philips.com/files/1/170b1a/170b1a_dfu_aen.pdf
170B Product Features
- 17" color LCD monitor with excellent display performance.
- Dual input-accepts both DVI Digital and VGA Analog input.
- Advanced AUTO adjustment automatically optimizes picture quality.
- Wide viewing angle technology.
- 7.1 (181mm) small footpring with full detachable cables.
- USB Bay for upgrade to USB Hub.
- Optional protective cover to prevent LCD panel damage.
- Standard VESA mounting holes and optional tilt/swivel Wall Mount Kit.
But if yours does have these ports, I would suggest they are not for a headset, but for connection to the _PC_. I would suggest your model monitor has built in speakers, and the green port is the INPUT from the PC Speaker output. The pink goes back to the PC from the MIC which is built into the screen.
Apr 21, 2009 | Computers & Internet
Monitor
Nov 05, 2008 | Philips 170B4MG 17" LCD Monitor
Phillips 170b monitor not working
Exactly the same problem here. Phillips 170B Monitor about two years old. Lights up for no more than 2 seconds then goes blank. Switch on/off and exactly the same thing. I suspect than the screen goes really dim rather than switching off because sometimes I can see the screen image very faintly.
Dec 31, 2007 | Computers & Internet
Philips 170B4MG 17" LCD Monitor Logo
231 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
