Question about Hoover U5264-930 TurboPower Bagged Upright Vacuum
Problem with wheels
When I start up my vacuum it smells like rubber.  I think the adjustment for the different carpet types is broken. the wheels appear to be sitting to low, making the brushes sit right onto the carpet.  I can't tell if a piece is missing or how to re-attach adjustment piece.  Help!
  • 126 Answers
If the belt is over a year old, it should be replaced. This is normal maintenance and is often overlooked. When the handle is in the upright position, it will appear the the height adjustment is not working. What's actually happening is that the height adjust is easily moved so you can make any adjustment you want. When the handle is pulled back, the front of the machine will lower to that setting and lock, so it will not adjust itself while you are vacuuming. If you wish to change the setting, you have to return the handle to the upright position, or you can lift the front of the machine with your hand, taking the weight of the machine off the wheels and this will allow you to slide the adjustment to another position. It is possible that the adjustment mechanism has come apart. It is comprised of three separate components. It would be very difficult to explain it here and should be addressed by someone familiar with this model.
Posted on Jan 13, 2008
I have a simplicity freedom Model S10E we cleaned out the hose and now it will not self adjust to my carpets. I have one carpet that is higher and its hard to push and I have a rubber smell
The rubber smell is the belt slipping up against the roller since it does not have enough friction to fully turn the roller. Either fix the adjustment for a high carpet or install a tighter belt that can cope with the job.
Sep 06, 2017 | Simplicity Vacuums
Powerhead won't rotate on low-pile carpet
Sounds like the vacuum is adjusted too low on the carpet. Adjust it to a higher level. If this is not the problem, then the belt is slipping. Buy a new belt.
Dec 02, 2015 | Hoover Vacuums
How do I adjust the power cam locationpower cam on a dc27
Hi Charles, it's Jack at Dyson.
DC27 is engineered to adjust automatically for different floor types - there is no way of manually adjusting the height of the wheels or brush bar. The vacuum may need higher push force on certain types of deep pile carpeting. We would recommend checking directly with the carpet manufacturer for their advice on caring for this particular carpeting - manfacturers may recommend vacuuming some carpets with the brush bar turned off, and it may be worth giving this a try.
To turn off the brush bar, just use the brush control switch next to the red on/off switch:
Jun 19, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
Nov 03, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Burnt rubber smell when vacuuming
This could be a few things:
A. If your model has a floor selector switch (Bare floor/tools - Carpet) your clutch could be worn. (there is a rubber clutch pad between your cam and roller shell) - Fix would be to replace the clutch pad and belt.
B. If you don't have one of the above models, your belt could be stretched. The belt slipping could cause a rubber burning smell. Fix - Change belt.
C. Have you got any new carpet you are vacuuming or have you moved? Some of the newer style frieze carpets can cause burning rubber smell. The fibers of the carpet are longer and cause the brush to slow down causing the belt to burn. (Imagine brushing long hair with a thick brush, the hair easily gets tangled in the brush, same effect with this carpet.) Some of the newer rugs can do this as well. Some newer carpets with the thicker felt backing and/or the "pet padding" under the carpet can too. it doesn't allow enough air to flow through causing the cleaner head to seal itself to the carpet causing a burning smell. The fix is Move to another home, replace your carpets or replace your vacuum. The vacuum is the cheaper option but be cautious as most vacuums now do this with these carpets. We have had really good response from customers using the Simplicity Tandem Air models, (Synchrony and Synergy models.)
Hope this helps, if you need to talk further feel free to contact me.
Tim
TheVacCenter.com
Mar 13, 2013 | Simplicity Vacuums
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Apr 08, 2009 | Dirt Devil M085850 Featherlite Bagless...
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Hoover U5264-930 TurboPower Bagged Upright Vacuum Logo
685 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
