Question about Toshiba 61HX70 61" Rear Projection Television
How do i fix my toshiba flat screen 57" tv when it looks like it is 3d
  • 927 Answers
Howdy;
It sounds like the convergence IC's have failed.
Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is detected, it’s recommended that both IC’s be changed to the “T” type IC version. Inspect the Convergence Output IC’s for the “T” type version.
1420-B Toshiba Dr.
Lebanon, TN 37087
Fax: 615-444-7520
www.tacpservice.toshiba.com/tacp
Good Luck, Big Irish.
Posted on Nov 23, 2009
SOURCE:
I have a Toshiba 57H82 rear projection tv. It has colored wavy lines on the screen and no picture.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 19, 2011 | Toshiba 57H82 57" Rear Projection...
Got used Toshiba 57H81 and picture is fuzzy like 3D. Touch focus error message shows.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H82 - 57" Lower left of picture screen
If the TV looks zig zag or scrambled and its moving aroudn the screen the hypermodule has failed.
If however it looks 3D or warped and is not moving around the convergence is the issue. You can get DIY repair kits including all parts, instructions, and support from sites such as www.TvRepairKits.com
Feb 22, 2011 | Toshiba 57H82 57" Rear Projection...
Upper corner of picture looks like 3D. picture on upper corner looks like it is off vertical with this happening. What do you do to fix this Hitachi 57F500 model?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 21, 2011 | Hitachi 57F500 57" Rear Projection...
Picture started flashing like 3-D in the hd ed mode
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Toshiba 57HX81 57" Rear Projection...
Sorta looks like 3d red&green mostly also has red lines arching across bottom 1/2 of screen
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Zenith R57W46 57" Rear Projection...
Magic focas not working in the auto mode, stops half way through the process. what can i do to fix this.
  • Screen looks 3D
69189a5.pngCONVERGENCE SOLUTION
Jan 11, 2011 | Hitachi 57SWX20B 57" Rear Projection...
Getting a 3d image picture and a bow at the top and bottom of screen what is it?
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Feb 03, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Picture is messed up
need to replace convergence control chips
Jun 12, 2009 | Televison & Video
Toshiba 61HX70 61" Rear Projection Television Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
