Question about Sanyo HT32744 32" TV
Can't see entire picture
I can not see the top and bottom of the picture on my TV. Also, it looks like the sides of the picture are being cut off as well. I greatly appreciate your assistance!
  • 1 more comment
  • Anonymous Feb 12, 2008
    can't see top and bottom of picture, including words like on a football game, for seeing the score
  • lateralus517 Feb 20, 2008
    I have had this TV less than a year. Now my screen turns green on the ride side sometimes. Any suggestions? I'm really frustrated!!
  • ivygusa Jul 12, 2008
    i can not see the bottom of my picture on tv. there is also at least 2 inches black space at the top of the picture.
    Genius:
  • 1,554 Answers
First if you are using time warner , hit the zoom button on the remote "#"
if thats the issue its done.
if not then the driver for the height is going out.
this is normally not a user adjustment now days.
Posted on Feb 17, 2008
  • Karl Whisenand
    Karl Whisenand Feb 20, 2008
    IF you have a speaker or phone with a magnet inside it and lay it on the tv or near it the picture will have green in that area.
    it will go away gradually as you turn on the tv each time as it demagnetizes the screen
6ya staff
SOURCE:
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
Can't read Subtitles
Look on your TV remote for an aspect button. There are usually several different aspects to choose from.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
My TV picture cuts off on the top and bottom
Check what format you are in. 4:3 is like a regular tv. Sides will be cut off in this format on a widescreen tv. 16:9 zoomed will cut of top & bottom slightly. You want just regular 16:9. No zoom.
Apr 08, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Olevia 232-s13 tv - screen is cut off and cannot see top and bott
The TV is set on zoom. Just go to the remote control and look for the button (not sure what is is on olivea usually zoom, P. size, wide, stretch or something similar though). just press the button until you cycle through to normal (on an analog signal it will have black bars on both sides).
Mar 24, 2009 | Televison & Video
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
Sony 46" Rear Projection HDTV Bad Picture
Hello, I also have the kp53xbr45 and I am looking for a red bulb, where can I find one at a good price? Thanks
Feb 09, 2008 | Sony KP-53XBR45 53" Rear Projection...
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Graphics are cut off.
First, have you made any adjustments to the tv other than from the setup menu? If not I have the service manuals for the tv in pdf files and would be glad to send them to you. Let me know I have the same tv and corrected the same problem. v/r, Scott
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
sounds like a sustained board not really sure a picture would help is it just on one side?
Mar 21, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Sanyo HT32744 32" TV Logo
229 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
