Question about Ecoquest Fresh Air Air Purifier
Fan Noise We took the machine apart and did the monthly cleaning, but when we turned the machine back on it made a horrible and constant noise.....I'm assuming it is from the fan as none of the other parts are cracked or need to be replaced.
  • 1 more comment
  • GilMichelini Jan 31, 2008
    My unit is at least 2 years old and doing the same thing. Sprayed at little WD40 down the shaft and that seemed to help.
  • smiley778 Feb 21, 2008
    I have the same problem. I sprayed the fan with wd40 and it didn't help. My unit is about 5 years old.
  • Anonymous Oct 23, 2008
    Same problem, but my fan motor housing is rusty.
  • 4 Answers
Your fan motor probably needs additional maintenance, in the way of lubrication.
After removing the unit from power, access the Fan blade and spin with finger. If there is any resistance to note then the spindle running through 2 bearing surfaces needs lubrication.
See the other question/answer to fan removal - motor lube.
If you have any sort of humidity to contend with and have a FreshAir model F1 or earlier different type, they seem to have some corrosion problems after a period of a couple years.
It is just a function of the machine/job that necessitates such maintenance.
Posted on Feb 05, 2008
Make sure you lay the machine down on its back when you lub it. The oil will lub behind the fan. WD 40 works.
Posted on Jun 10, 2008
Broken Fan Blade
No usually original equipment parts only.
Oct 03, 2013 | Hunter 30735 Air Purifier
Hunter Air Purifier making screaming noise
Most likely the problem is a bad bearing in the fan motor.
May 31, 2012 | Hunter Fan Company 30251 Air Purifier
How do I fix the noise?
let it dry completely, disassemble as you would for cleaning, and remove filter unit. Inspect to make sure no paper or other debris like a seal has been dislodged. If you can see fan blade, see if it will turn with filter removed. If it moves easily, reassemble carefully and make sure the contacts are oriented correctly and any charcoal filter is on place as well. Try unit.
If noise persists, the unit has to be opened up to inspect bearings of fan/motor and to locate and remove any debris. At that time a drop of light sewing machine oil or pellet gun oil to lubricate the bearings is a good idea.
Jan 23, 2012 | Air Purifiers
How do I know when it is time to service my Living Air 880?
This is one of the first models manufactured by Alpine, and is at least 15 years old. It's pretty basic, however, and if it's maintained monthly or bi-monthly, it probably will just keep on going and going...like another little advertising icon says!
The two most important parts are the white plates with the screens attached, and the fan. If the machine is making strange squeeking or grinding noises, the fan needs oiling. Even if no noise is audible, the fan still needs oiling occasionally, like any fan in any appliance.
To:oil:
1) Unplug the machine.
Remove the front grid, gently but firmly pull off the fan blades, and
Feb 18, 2011 | Alpine Air Purifiers
Honeywell Furnace Air Filter clicking noise after cleaning it
I also have this problem as soon as I pt a new filter in - does anyone have a clue what this problem is?
Apr 09, 2010 | Honeywell (F50F1032) Air Purifier
The fan makes noise when turning
It probably need oiling. The fan motor should be oiled at least every two months. For complete cleaning instructions (including oiling) e-mail to miller@healthyti.com. Ask for their free cleaning instructions. They will be glad to help.
Jun 25, 2009 | Ecoquest Flair Air Purifier
Clicking noise
after cleaning is it dry. you might want to take apart and see what is clicking wheel or some thing hard to tell since i can't see it. as far as options . check with the manufacture google it check them out on line hope this helps. Tom
Jun 20, 2009 | Brookstone Pure-Ion (506840) Air Purifier
Rainbow Rainmate making a screeching noise!
just take it to ur local dealer they will replace it or fix it.
Feb 12, 2009 | Rainbow Rainmate Air Purifier
Oscillation stopped working!
Sounds like the drive gear is stripped.
Nov 20, 2007 | Bionaire BAP1500-U Air Purifier
Ecoquest Fresh Air Air Purifier Logo
368 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
