Question about Tomtom GO 300 GPS Receiver
Tomtom300 gps mains charging +
Hi, I have 3 questions to ask please about my tomtom 300 sat nav:
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
2= But when i put it in car charge it works perfect 'Y'?
3= If ever i have to change battery how is this done?
Thanking you Look forward to all replies. Rob
  • BLhall Jan 16, 2008
    Similiar problem. Unit works when I have it attached to car charge but battery doesn't seen to be building a charge.
  • 174 Answers
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Posted on Jan 16, 2008
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
Ay to be sat nav
you need to install the update from this link, I've just done it and my Aytobe sat nav is working much better and it's holding a charge too
Mar 20, 2009 | Tomtom One XL GPS Receiver
How do I charge the TomTom XL 330
Hi There!
You Can charge your Tomtom when you drive, or you can charge it with a USB port on your computer.
I don't think they come with a mains charger anymore?
Dec 26, 2008 | Tomtom XL 330 Car GPS Receiver
Tom tom rider version not charging via bike cradle either via direct connection to the bikes battery or when connected to an aux power socket. There is also no sound while attached to the car cradle /...
I recently had a bit of success with TomTom. My TomTom Rider 1 did not charge on the bike cradle, there is a known problem with the early cradles. TomTom have developed a TomTom Rider 1 replacement cradle (updated) and if you push hard they will wend you one in the post free of charge.
Jul 27, 2008 | GPS
hi Dazza here go to tomtom home 2
Mar 23, 2008 | Tomtom GO 300 GPS Receiver
Tomtom go 300
The tomtom GO 300 does not need an installation disk. It has firmware ( thats a sort of pre-installed software ) that is put on it at the tomtom factory. If the firmware has become corrupted it can be reinstalled or "updated" by logging on here > then click the DOWNLOAD TOMTOM HOME Link. Then connect your tomtom to your computer with a USB lead. Run the TomTom-Home software you downloaded and select "UPDATE MY PRODUCT" . After that , if you don't already have one you will need a valid SD card for your tomtom containing the maps for your country and some other activation codes which you get when you purchase maps from tomtom.
Jan 25, 2008 | Tomtom GO 300 GPS Receiver
When i plug into car ok but when to mains nothing
First , let me say that the batteries do not fail very often. Answers here to your 3 questions in order ......
1. Your home mains charger is faulty. 2/ Your car charger is probably OK. 3/ Clip out the screen surround. Remove the 4 special STAR screws that are at the corners of the screen. Remove the main circuit board by taking out 4 smaller star screws and let it hang loose but still connected by its cables. DO NOT DISCONNECT THE BOARD CABLES. Remove the speaker . Under the speaker are 2 more screws holding a plastic bracket that clamps the battery. Remove these 2 screws and the battery clip comes off. Unplug the battery cable from the now loose main board and the battery can be removed. Fit new battery and reassemble in reverse order. NOTE , some tomtom 300's have a protective copper or foil sheild covering the main board. The screws holding the board cannot be seen until the foil is removed. Removing this foil and not repalcing it will render your tomtom more prone to interference although the tomtom will still work without it.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Tom tom one activation code
you might be able to get you device code by:
select the main menu
select the change preferences
scroll through till you find 'show version'
select it & it may display your device code at the top?
Dec 08, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
205 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
