Question about Sharp 13VT-N100 Combo
Cannot switch from "air" to "cable" w/o remote
Tv also says "timer recording not finished". I do not have a remote nor do I see a button to switch it to cable.
0 characters
1 Points
F2-1000T Digital Set-top Box.
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
Aug 05, 2008 | Combination Televisions
I need to re-program my toshiba tv to get basic channels after i just had th cable box removed. how do i re-program it on the remote?
But u still have and pay for the basic cable service wright?Yes,just used the tv remote and push the remote menu button than go into the tv menu,go into Setup enter and go down and pick CABLE not AIR.Enter for the tv do scanning for cables channels.After finish scanning u will get all the basic cable channels.
Jul 13, 2011 | Toshiba MV13M2 13 in. TV/VCR Combo
Can not get remote to switch from video to tv so that I can change from air to cable. Go to input and it says video and no button on remote moves over to tv. Push all arrows available
I had that problem with my comcast remote and all I do is hit TV button on top of remote and the the tv/ audio button and it switches.
Dec 12, 2009 | Combination Televisions
try to use the buttons from the TV.
Jan 29, 2009 | Sharp 13VT-N100 Combo
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
Jan 23, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
Doesn't record when timer is set.
I found the manual and helped me get familiar with the remote etc. Tech. support solved my problem i was pressing the otr rec button instead of the timer rec button. Ken.
Nov 03, 2008 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Rca tv/vcr combo model T13208
Recording speed is the last item on the timer programming. SP or SLP. Some remotes have a button that will allow you to change the speed, when recording manually.
Sep 12, 2008 | RCA T13208 13 in. TV/VCR Combo
Would like to switch tv mode to cable mode
go to the menu button,press it, in menu service you to choice either air or cable. then select the cable
Nov 06, 2007 | JVC TV-13142 13 in. TV/VCR Combo
How to set timer without remote
Nope, Im sorry to say you have to use the original for these functions to work. Go to and get the proper remote.
Sep 27, 2006 | Toshiba MV13P2 13 in. TV/VCR Combo
Sharp 13VT-N100 Combo Logo
75 people viewed this question
Top Sharp Combination Televisions Experts
matt martin
matt martin
Are you a Sharp Combination Television Expert? Answer questions, earn points and help others
