Question about iRiver Clix Digital Media Player
Iriver "USB Connected" screen problem
My daughters 1st gen, iriver Clix MP3 player is stalled at the USB Connected screen. I tried reseting the damn thing but it will not work. Any suggestions before suicide?
  • 209 Answers
Re: iriver "USB Connected" screen problem
Before suicide, first consider your daughter ;)
Then make sure the USB ports and cables do not have a lot of dust in them.
Unplug and try it in a different port[also those in the back of your computer]
Make sure you have the driver installed.
Hope that helped, if not, reply with more details.
Posted on Jan 12, 2008
0 characters
3 Points
Iriver Clix 2 8GB connecting to PC problem
Usually it have to, but if is not use iriver plus software !! or see if u have drivers properly installed.
Apr 28, 2009 | iRiver Clix Digital Media Player
Iriver clix gets static-y after a few minutes
Hello Cart, I am sorry to hear that your Iriver Clix Gen 2 4 gb video player recieves enormous amounts of static that makes it unaudible after a couple minutes. I see that you have eliminated one of the factors of static by upgrading the firmware, but unfortunately the firmware is only related to booting up, and loading your movies/music. If the static is coming from the speakers, you may not be able to fix it, unless you open up your Iriver Clix, which I recommend you not do, due to that it will void your warranty. The Static may be caused due to excessive geforce or impact to your device, causing the wire's to be loose. If the static is coming from the speakers, I would recommend you to return it to the manufactuer or return it back to the store. If the static is coming from the 3.5 mm plug, try a different pair of headphones or earbuds, make sure it is fully plugged in, I would also recommend you to return back to the manufacturer, or return it back to the store. -Tom Smith.
Aug 26, 2007 | iRiver Clix Digital Media Player
IRiver Clix Freezes Up
I had the same problem. Sent it back and got a new one. They said it is a cold solder issue.
Mar 18, 2008 | iRiver Clix Digital Media Player
Iriver Clix USB freeze
My screen also froze in the music menu, but when I connected to the PC, it was recognised and I could get into the files. Try resetting it by sticking a paper clip in the reset hole if you've not done it already. Mine's working fine so far....
Feb 17, 2008 | iRiver Clix Digital Media Player
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Dec 30, 2007 | iRiver Clix Digital Media Player
Flash Games Don't play?
If you reformatted from Windows Media Player on the PC you need to reformat again using the "Format" command on the Clix player itself under "Settings" "Advanced".  I am also assuming you already tried to press the reset button on the player.  If you have already done these two actions someone else will need to suggest a solution.
Oct 30, 2007 | iRiver clix 2nd generation MP3 Player
Iriver MP3 player
the same thing happened to my iriver it means something you have downloaded had a virus and you need to have the device serviced
Sep 25, 2007 | iRiver Clix Digital Media Player
Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
Aug 06, 2007 | iRiver Clix Digital Media Player
Iriver Clix (Gen1)
i lost the driver of my iriver clix gen1 2gb please send the driver on my email address thanx my email is
iRiver Clix Digital Media Player Logo
153 people viewed this question
Top iRiver MP3 & Digital Media Players Experts
Steven Wander
Steven Wander
Are you an iRiver MP3 and Digital Media Player Expert? Answer questions, earn points and help others
