Whirlpool washer Mod: LXR9445JQ0
  • Smyjdak Feb 15, 2009
    I have the Haier XQ8M22-C PORTABLE TOP LOAD WASHER and just recently it began to make a grinding noise. I sprayed some WD-40 in the back and the noise mostly went away but then it never finished spinning. What is does is it starts to spin up but never actually reaches any speed and eventually it just finishes the wash without the "finished tune" and the clothes are still soaking.
Won't spin dry
Posted on Mar 18, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
Whirlpool model #WFW9150W front load washer. Washer makes lots of noise when operating
If it sounds like a freight train in spin cycle most likely it is your bearings. If it makes a clunking noise during the wash cycle you have a broken support. The best way to tell is to spin the basket by hand and listen for the noise. Check to see if the basket is making circles and not ovals. Pull back the rubber seal and look signs of the basket rubbing against the outer plastic tubs. If is either one of these it is cheaper to buy a new washer than to fix it. Fixing it involves rebuilding the machine. If it only makes the noise when it starts to drain you need to check your pump for foreign objects.
Jul 12, 2011 | Whirlpool WFW9150W Front Load Washer
Missing balance ring clips on whirlpool washer model # LXR9445JQ0
just buy the clips, watch a video to remove the housing of the washer. it is a simple fix. should be below $20 to get the clips, j
Jul 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
Loud noise (like a generator) when the washing machine goes into Rinse Cycle and Spin Cycle. What is wrowg with it and what parts needs to be replaced ?
Will it go through the wash cycle now? If it does, then it's more than likely the transmission. If it makes the noise in wash cycle now, it's probably the motor coupler.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Whirlpool Duet. Strange noise and F 02 error code
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bad noise at begining of rinse cycle.
It sounds like your gear case (transmission) has gone bad. If the washer fills and agitates that tells me that the problem cannot be with the motor coupling and drive motor. It also rules out a pump problem if the washer completes a wash cycle and drains properly. The only thing left is the gears inside the transmission. Sometimes they go bad in a way that portions of the wash will work while others don't. The part number is 3360629 and the price usually runs about $150. I hope this may help you in some way.
Sep 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
282 people viewed this question
Top Washing Machines Experts
