Question about Toshiba Satellite M35X-S163 Notebook
Frozen Computer My laptop is frozen on an "In Touch with Tomorrow TOSHIBA" screen. It says to press F2 for setup and F12 for boot device selection menu at the bottom, but it wont do anything and I dont have the recovery cd. Can anyone help me?
  • rebecca cantrell Nov 04, 2011
    mine only has the "IN TOUCH WITH TOMORROW TOSHIBA " on it and nothing else and wont do nothing else and cant really affod to do much with it. Should i just get new one?
Notebook is locked up
Posted on Nov 29, 2008
    Sergeant:
    Champion:
  • 310 Answers
If you know some one with a xp disk you can use it as a tool to boot up. Once it is booted up it will write a log file and it should work
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 12, 2008
Just install new hard drive in my laptop....old one frozen. i have an activation key for windows 8.1 pro. how do i install new operating system?
Boot from your installation disc. Insert the installation disc into your optical; drive, and reboot your computer. Normally a computer boots from the hard drive first, so you will need to adjust some settings in your BIOS in order to boot from the disc drive. You can enter the BIOS by hitting the designated Setup key during the boot process. The key will be displayed on the same screen as your manufacturer's logo.
  • Common Setup keys include F2, F10, F12, and Del/Delete.
  • Once you are in the Setup menu, navigate to the Boot section. Set your DVD/CD drive as the first boot device. If you are installing from a USB drive, make sure that the drive is inserted and then select it as the first boot device.
  • Once you've selected the correct drive, save your changes and exit Setup. Your computer will reboot.
Oct 31, 2016 | Computers & Internet
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
The computer is not starting automatically eventhough the power button is switch on. The screen only shows the message" In touch with tomorrow", Theres two choices to press,F2 for Set up menu and...
Remove the Power cord and battery
Hold down the ON button for 30secs (dispersing all internal voltage)
Plug the power cord back in (leave the battery out for the moment)
Turn on
Does it work?
If so, shutdown normally
Re-insert the battery
Turn back on
Mar 16, 2011 | Toshiba Computers & Internet
Hai my name is laman my lenovo laptop just haveasmall problem it's displays only press {f2} for set up press f12 for boot device selection & can not execute so any one please solve this problem
Pressing F2 is the shortcut key to enter in cmos setup or bios settings where you can setup interrupt request and the direct memory access and also changing system date and time. While the F12 key is a shortcut key where you can select a boot device which are the hard disk drive if it's loaded with the operating system like windows xp or windows 7 etc., and if you are going to install or reformat your computer select the cd/dvd room drive to be the boot device. Supposedly the computer will load after the F2 or F12 appears on your screen if you have the functional operating system. But if your computer still restarting and always appearing on your screen the said F2 and F12 keys that means it is required to be reformat your computer. But before that you try to tapping F8 key while turning on your computer and select safe mode and press enter, after loading and still restarting that is the time to format your computer but you must back up your data or files that you saved on your computer. Call a computer technician or IT that know how to back up and can format your computer. Have a nice day.
Mar 14, 2011 | Lenovo Computers & Internet
Hello, the problem with my mini toshiba nb200 is that when I on it, it shows the initial screen which says ; TOSHIBA Leading Innovation >>> Press [F2] for ...
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 05, 2011 | Toshiba Satellite A205-S4617 Notebook
Zenith director laptop, after switching on the system, press F2 for bios setup and F12 for boot setup screen appears and hangs up. What to do?
If you need to boot your cd you not need to press F12 just after entering bios setting goto boot configuration and change your first boot device to cd\dvd and press F10 and select yes.
Dec 08, 2010 | Computers & Internet
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
Dec 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A135-S4427 Frozen
there is problem with the mother board try repairing at repair shop
Nov 29, 2008 | Toshiba Satellite A135-S4427 Notebook
Bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Toshiba Satellite M35X-S163 Notebook Logo
227 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
