Question about Toshiba Satellite M45-S165 Notebook
Dvd ram region locked.
Hello, I have accidentally used up all the the region changes for my Mashita DVD-RAM UJ-840s. Can i undo my last change back to region 2? I have tryed restoring the system to an earlier time this didnt undo my change. Also i have searched and cannot find any firmware for this device to make it region free...please can you help? Chris
  • 188 Answers
Re: dvd ram region locked.
Once your drive is locked im not sure you can do anything. I found this site which may work but i havent tried it.
Worst case replace the DVD drive.
Posted on Jan 12, 2008
0 characters
3 Points
Download driver fore install on DVD-RAM mashita UJ-850S
that wont work in your asus that will only work in a toshiba,,, sorry
please vote!!
Dec 02, 2010 | ASUS A9RP Notebook
PHILIPS CDRW/DVD SCB5265 ATA Device cannot play most DVDs
I'm guessing you may have locked the DVD region. If you right-click on the device in Device Manager and click the Region tab, does it say 0 changes available? Acer won't fix this, and claim you have to replace the drive. Can't find a firmware flash for this drive online, will post back here if successful!
Aug 14, 2009 | Acer Aspire 5535-5050 Notebook
How can i reset my cd/dvd region in my acer aspire 4715z series, i plan to do this my cd/dvd rom is choosing a disc to play, i think some change the cd/dvd rom without my knowledge and I'm not able to fix...
To change the region code on your DVD player go to Control Panel - System - Hardware - Device Manager and expand the DVD/CD ROM drives, then right click on your DVD drive and click on Properties then click on DVD Region tab. You will see the number of changes remaining (you can only change the region code 4 times and then it locks on the last region change and no further change is available). You will see the Current Region and You can change the region in the New Region box.
If you have run out of changes then you have a problem, this can be fixed. The hardest way is to upgrade the firmware on the DVD drive to a region free firmware BUT if you install the wrong firmware or stuff up the upgrade your DVD drive will be a piece of junk.
The best way is to install a piece of software that defeats the region code. There may be some free software on the Internet but I use DVD Region Free + CSS Free from DVD Idle, it not expensive and I have no problem viewing DVDs from any region.
Use this link to DVD Idle WEB site.
Jul 28, 2009 | Acer PC Laptops
I need find driver on Mashita dvd ram UJ-850s on laptop Acer Aspire 3100.
May 02, 2009 | Acer PC Laptops
Mashita dvd ram uj-8505ata
I posted the solution on this site yesterday.
Dec 22, 2008 | Toshiba Satellite A135-S4527 Notebook
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
Is your DVD/RW. you may only have the dvd that can read disk. have you ever burn cd or dvd on this dvd rom.
To burn dvd you have to have the software.This does not come with the dvd. you have to buy one on your own
good luck
Jul 18, 2008 | Toshiba Satellite A105 Notebook
Matshita DVD-RAM UJ-840S problems
if the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
Apr 26, 2008 | Toshiba Satellite M45-S165 Notebook
Zoned DVD Drive
I think you let it be the same( the last chance) and try to get this 2 software any of them
2.dvd regูion free
** this 2 program will make region zone free
*** check this 2 program out by typing the name at
Apr 19, 2008 | Toshiba Satellite M45-S355 Notebook
Toshiba Satellite M45-S165 Notebook Logo
83 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
