Question about Nikon Super Coolscan 4000 ED Film Scanner (35 mm)
Overall Blue Tint
I haven't used the 4000 in a while. I lit it up today and started scanning some slides but the results are all tinted with an overall blue.
I'm using Nikon Scan 4.0.3 on a Vista machine.
Anyone seen this before?
Thanks...
  • 3 more comments
  • Anonymous Jan 27, 2009
    Resetting to default is not working for me. I'm seeing the same blue tint. Any other ideas? Thanks.
  • Morton Johns Feb 11, 2009
    Same scanner with a Mac, I've used it for a long time but the same problem developed for me today - overall blue tint, reset to factory default doesn't help -
  • Anonymous Feb 23, 2009
    needs cleaning they told me at nikon, reset do only help sometimes
  • Anonymous May 06, 2009
    I have exactly the same problem - havnt used it for a while -blue tint on everything -factory reset does not correct it neither will it adjust afterwards using photoshop.
  • Anonymous May 07, 2009
    Tried resetting and nothing. The light is clearly magenta as it moves across during the scan. I would have thought it should be white. Is an LED blown?
  • 4 Answers
You might try resetting the "settings" to factory defaults and then scanning again. I have seen strange tints if the settings get set incorrectly, not sure exactly what is wrong. However, using factory defaults corrects the problem, then change settings one at a time.
Posted on Feb 04, 2008
I need to get rid of the blue tint on all my pictures
Have you checked your camera's white balance setting ? Try setting it to 'Auto' and see if that helps. If not, then there may be a fault in the camera's electronics, which would indicate repair or replacement.
May 30, 2016 | Cameras
All photos are printed with a blue tint behind them.
#Perform print head nozzle cleaning from printer properties..
# Do align print heads.. check.. repeat 2-3 times till good result comes.
Aug 02, 2015 | HP CR769A Officejet 7610 Wide Format All...
Turned on computer today and my screen is blue green, does not change using monitor buttons?
Sounds like you are using an analog standard VGA cable interface. Since the menu has the correct coloring, it is not the monitors fault. Check the connections of the video cable at each end to ensure they are tight and not kinked. If they are ok, try using a different video cable. If thew problem still exists after that, it is probably the video card in the computer.
Apr 11, 2015 | AOC Computers & Internet
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
No matter how |I try I cannot adjust the projector
Don't know this model but try the colur temperature- turn it down to the kelvin temp. (sorry is this is a too obvious solution- hope it helps)
Jan 08, 2010 | Epson (ELPLP25H) Projector Lamp for...
Grainy and red tint on component video inputs from
Usually when you have a red tint when using the component input i'ts because the wires are switched on one end or one of the 3 video wires is bad. See if blue and green are switched.I see this all the time. Is your picture grainy on all input?
Nov 22, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Color balance is bad
Have you tried cleaning the slide holders/adapters?
Jun 11, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Green Tint
bad optical block call sony they have a recall
Jun 01, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Green Tint
Green tint is caused by a burned or distroyed filter in the optics. It must be removed and sent out to be
rebuilt or replaced.
Mar 21, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Nikon Super Coolscan 4000 ED Film Scanner (35 mm) Logo
779 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
