Washing machine The washer works, but does not agitate. The motor makes noise but does not turn anything. I took it apart thinking I would maybe see a belt broke or something, but I don't see anything. I thought I would try looking this up on the internet for help, but it's hard to find answers. Please help me. I need to know if it is fixable or just a pile of metal waiting to get scrapped out. This is my first time searching problems out on the internet through real people, so please help make it good for me. I would appreciate any advice or info. Thank you very much.
  • 2 more comments
  • modeleng1 Mar 05, 2008
    I have had the same problem as you anita wiseguy. Have you sorted the problem? was it the kenmore drive coupling as described?
    I could certainly do it myself(engineering background) rather than pay ridiculous price for someone to do it?
    Thanks, Alan
  • Raider51 Sep 14, 2008
    Frigidaire washer machine #FWTBB30DS0 have same problem, Also skips cycles
    Frigidaire washer machine #FWTBB30DS0 have same problem.Also skips cycles?
  • Michael  Lindley
    Michael Lindley May 11, 2010
    I usually bypass questions without brand or model number information, but your comment about this being your first attempt caught my attention. If you will post the brand of washer and the model number if you can find it, I will try to help.
  • 290 Answers
If it is a direct drive Kenmore or Whirlpool washer, then most likely you have a broken motor coupler.
Post back with any questions.
Posted on Jan 12, 2008
Washer filles with water then buzzes
hi Timothy.
  1. Blocked Drain Pump: An object has lodged itself inside of the drain pump. There can be items such as a small sock, a coin, a toothpick, or something small in your clothes pockets when you wash them. These items can fall out of the pockets and end up in the drain pump causing it to become blocked and make the buzzing noise you hear. Here is an audio recording of a blocked drain pump. Unfortunately, the only way to fix this problem is to take the washing machine apart and open up the pump and remove the object causing the buzz sound. To find directions to take your specific washing machine apart, do a Google search for Make and Model of your washer.
  2. Motor Coupling Broken: The motor coupling has broke and the motor turns but nothing happens. This will also cause a buzzing noise which can also be described as a vibrating noise. To fix this issue you will need to take the washer apart. Here is a video to show you what to look for if your washer motor coupler is broken. Once you know that the motor coupling is broken and needs replaced, we recommend ordering the part online. Simply do a search for "washing machine model motor coupler" and you will find the part needed for your specific washing machine.
  3. Washer Drive Block Loose or Worn: The washer drive block is not tight or has worn out. The part will need to be replaced to fix this problem. Here is an audio clip of a worn washer drive block to help you to diagnose that this is your actual issue. To further assist you with this issue, here is a video to show you how to replace a washer drive block.
  4. Worn Agitator Dogs: When these are worn, you will hear a clicking or crunching noise. These small plastic parts are used to turn the top of the agitator in one direction. This pushes the clothes down to the bottom part of the agitator to be washed. Here is what your washing machine will sound like when the agitator dog ears are worn. To replace these, order them online (about $5 bucks) and then install them in your washer. Here is a video to show you how to remove and replace washing machine agitator dogs.
  5. Washer Motor Burned Out: This may result in a buzzing noise depending on circumstances. The way to tell a bad motor is a distinct burning smell. This usually means your washing machine is old and the motor has died from old age. You may need to start thinking about buying a new washing machine. if that is not possible, you can buy a new washer motor for around $100 and install it yourself. Here is video showing how to remove a washing machine motor.
or try this.
Drain hose: If the washing machine is functioning correctly but makes a hummingsound while draining, there could be a problem with the drain hose. ... Then unplug thewashing machine and turn off the taps supplying water to it. Unscrew the fill hoses from the water valve.3 Nov 2014
Why Is My Washing Machine Humming? -
Based on your details, I would first check the drain pump to see if it's locked up due to a piece of clothing stuck inside the pump. You can remove the pump from the motor leaving the two hoses attached and then see if the motor will start. If it continues to just hum instead of starting, then it may be losing the start voltage. The motor needs start voltage and run voltage in order to start. The motor will just hum if it's not getting the start voltage.  The start voltage circuit is usually the red and yellow wires. Check the yellow and red wires at the motor, capacitor and at the timer for a loose connection. Make sure the red and yellow wires are pushed in all the way at the timer terminal quick disconnect plug. 120 volts should be present when measuring across the red and yellow wires. Check the white wire with the black stripe too at the timer and motor.
Washer filles with water then buzzes Google Search
Nov 24, 2017 | Washing Machines
Maytag agitator will not turn
Sounds of a loose motor or need brushes replacement.
Jan 13, 2018 | Maytag MAV6457 Top Load Washer
Roper washing machine is not agitating. Makes a horrendous noise when supposed to be aggitating. No noise when filling with water.
In addation to the agitation does it make the same noise in spin??
If yes it makes that same noise in spin the problem is going to be a broken motor coupler. I have written this tip about a broken motor coupler it will show ya how to take apart the washer and replace the coupler.
Oct 10, 2011 | Roper RAS8445KQ Top Load Washer
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
Whilrpool imerial series washer making strange noise
The agitaor coupling or drive mechanism is stripped. You will have to pull the agitator up out of the machine to find which of the parts need to be replace. Most likely th agitator coupling.
Jan 27, 2010 | Washing Machines
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
Feb 09, 2008 | Washing Machines
Washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. back.
Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
