Question about Microwave Ovens
Suction of my ge microwave
My new micwave does not seem to have enough suction to get the steam from the burners of my stove. What could be the problem?
  • Microwave Ovens Master
  • 9,176 Answers
The filter or the oven itself may be installed improperly, or there may possibly be a power line problem.
You can consult your owner's / installation manual to be sure there is adequate clearance in the installation.
If you don't have your manual(s) you can find them here:
http://www.geappliances.com/service_and_support/literature/
If you still have a problem, since it's new I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 12, 2008
6ya staff
SOURCE:
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
My surface light bulb burned out and I replaced it with a new bulb. But now the bulb stays lit and it won't turn off even though I turn it off from the light switch. Please help.
The only fix for it is to either buy another control board $300+ or if you are any good at wiring you can go the the hardware store get a manual toggle switch and install it under the microwave on the right hand side near the control area. But make sure the switch can handle the heat rising from the stove burners. We have about 120 of the microwaves on our properties and 6 of them have this issue. The relay internal switch becomes corroded and binds together from steam and boiling water. GE is JUNK.
Oct 30, 2011 | GE JVM1790 1000 Watts Convection /...
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
Jun 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Fan on over the range microwave does not have enough suction to **** the steam from stove through the microwave. Does the blower get turned a certain way for this to work? Is there a .pdf operational...
This may be caused by a weak fan, improper installation, clogged filters, blocked air ducts, or a blocked outside vent.
Assuming yours is a Whirlpool, you can download Whirlpool owner's manuals and installation instructions here.
This will help you check the mounting and setup, as well as helping you check the filters to see where the problem lies.
Please write back with your brand and model number if you yours is not Whirlpool.
Jan 02, 2009 | Whirlpool MH1170XS Microwave Oven
Cleaning vents
GE Spacemaker Profile X1800.
I would take out the grills and boil them, but cannot see how to do that.
Also, the GE stove top (Model JGSP44BEY) has so much baked on crud that I may never use it. I poured a whole bottle of easy off onto it and still cannot loosen it all. Same goes for the removable parts from the burners.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Partial venting
Are you running the vent fan whenever you cook on the stove top? You should.
And you should run it on high if you're having steam problems.
Otherwise, you'll need to do something like use a small counter top fan to help circulate the air better.
Please let us know if we can help further.
Random beeping and panel buttons not working
There may be a failure of some type in the system processor area.
Maybe some of the steam from the bioling water and oil and water from the cooking got inside on to the circuit board, and caused some damage.
It is also possible that the heat from the stove did some damage.
It is also possible that there was simply a failure in the system processor area.
Jerry G.
Apr 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Vent Fan
The only thing I did was to unplugged; turn off all the burners; and let everything cool off. I guess I can't have all the burners on at one time since the microwave is 13" from the burners......and from what I read "microwaves placed over the range" should be at least 30" from the burners...thank you, Rose66
Feb 20, 2008 | GE Microwave Ovens
Microwave Ovens Logo
174 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
