The following blog outlines some repair options for a lens error. They won't work for all cases (little less than 50%), but they're worth a try if the camera's no longer under warranty:
I am unfamiliar with the e-studio 18 but on other Toshiba e-studio models C41 is a fuser (hot roller) error and it will clear itself when the problem is corrected, there is no reset procedure. I would go back and be sure that the replacement was done correctly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
This is a common problem with D-90's. Nikon won't admit a problem, until they do not much can be done. I have to pull the battery to make my error message go away! I know this info doesn't help much, but your certainly not alone!
Technical details of permanent failure: Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 554 554 delivery error: dd This message is looping: it already has my X-Yahoo-Forwarded line. (#5.4.6) - mta1023.mail.sp2.yahoo.com (state 18). --
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSIPERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
